Breaking Survey- Everybody please give your input.
lil of both however...I should throw this out there...which would you rather wear out...brake pads 40 bucks
or tranny 250 minimum??
Nuetral more then not
Kick it to N before brake always (unless downhill for example, where I do both)
Like Drag said. Brake pads are cheap, and valves are not.
I downshift with the civic. It seems harder to stop then the Jetta. I am looking into a SI rear disk swap. The car stops fine it just takes more work.
I use more breaks than clutch.
I do both. If their is not alot of traffic Ill throw it in nuetral. However if there is Ill downshift incase I need to step on the gas to avoid someone.
