DropZone camber kit modification?
ok i hear that the dropzone camber kit is a decent camber kit for the money. I also hear that you have to do some cutting/grinding and what not to make it fit correctly. Is anyone out there who can tell me exactly what needs to be cut/grinded or whatever and tell me what is easily used to do this??? i'm getting one and need to know this. tia
On the left is my best drawing of part of the A-arm. The rounded part is where the camber corrector goes. On the right is one after modification. See how the corners have been cut to a 90* angle. All of them must have that done, and it only takes 5 min each (2 per side x 2 sides x 5 min = 20 min total).
-Dustin
Modified by krustindumm at 9:51 PM 10/2/2003
when you put in the camber and drop your car back down from the jack stands then you will know what needs grinding and hammering or cutting. if you wanna see some actual pictures, just email me and i will go take some pictures and sent it to you.
itsJDMyo
13
Jan 7, 2005 10:40 AM
