How do you change syncro? Taller gear?
Old Oct 2, 2003 | 08:46 AM
Doug684's Avatar
Default How do you change syncro? Taller gear?
Ok here's the deal. I have a 91 Civic HB SI. I am going with a ZC swap and decided to use my SI tranny because I hear it is better. Well my 3rd gear syncro is going out so I need to replace it. How hard is this? Would I be able to do this or should I take it to have it rebuilt? Where do I get the syncros from? Also I was wanting a taller 5th gear for highway use since I travel often. Right not I run about 4K at 85mph. If possible I would like that at like 2-2.5K Reving that hight for a extended time burns serious gas. Also the ZC is going to be turbo since I have a entire kit ready to install.
Old Oct 2, 2003 | 11:39 AM
e30dood's Avatar
Default Re: How do you change syncro? Taller gear? (Doug294)
It's not that hard but if you've never worked on transmission, I wouldn't touch it if I were you. You have to buy the whole 3rd gear synchronizer assembly and you can get it from http://www.hondautomotiveparts.com (Majestic Honda).
I don't think it's possible to swap a taller 5th gear over. But what you can do is use the dx differential instead or just get a dx tranny because it has the same gear ratios as the si just with a taller differential gear.
Old Oct 3, 2003 | 02:37 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: How do you change syncro? Taller gear? (e30dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e30dood &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it's possible to swap a taller 5th gear over. But what you can do is use the dx differential instead or just get a dx tranny because it has the same gear ratios as the si just with a taller differential gear. </TD></TR></TABLE>
Please refrain from thinking.........
88-00 5th gearsets are interchangeable. You have your choice of 5 factory ratios.
.694/.702/.750/.771/.878
You will use MORE gas by lowering the cruising rpms. TOO low and you will bog the motor, use more throttle, and therefore more gas!!!!!!!
I run a 4.250 FD and CRX Si 5th in my 93 DX HB with SOHC VTEC motor. Using 325 cc/min injectors I still get 38 mpg when cruising at 3800 rpm and 80 mph.
Old Oct 3, 2003 | 09:13 AM
xci_ed6's Avatar
Default Re: How do you change syncro? Taller gear? (Mista Bone)
Has anyone bought a rebuild kit for the trans, like all syncros/bearings/whatever? I was wondering what that would cost.
Before I put in the turbo on my hatch I could get 42MPG w/ 450s My si only gets low 30's, because it is geared shorter. OTOH my uncles nissan truck went from like 20mpg w/ a 5spd to 25mpg w/ a 4spd highway driving because 5th was too tall.
-Dustin
Old Dec 8, 2011 | 07:59 AM
geohue's Avatar
Found this thread as I am about to rebuild a CRX HF manual transmission. The kit with bearings, sychros, and seals can be found it BK326WS KIT for about $200 on ebay. If you don't need the Synchros, the kit is about $115. I checked Majestic Honda (part no 23626-PL3-325) and I think they want $130 for the Synchros only..
Old Dec 8, 2011 | 09:30 AM
droopy128's Avatar
Just an FYI, the mainshaft bearing on the SI/EX is different than DX/LX, which the kit didn't indicate, the rest should fit from the kit.
Old Dec 8, 2011 | 09:48 AM
TearSDMF89dx's Avatar
this is good info as i have a syncro crapping out in my si tranny right now....im going to put a junkyard trans in for now then go ahead and rebuild my si ....now the question does the hf 5th gear work in the si trans?
Old Dec 8, 2011 | 10:13 AM
droopy128's Avatar
^^ will work, you will need to changer out both 5th gears on the counter and mainshaft
Old Dec 8, 2011 | 10:48 AM
Nooch's Avatar
I'm going the same route basically too. 5th gear syncro crapped out completely finally and I can't shift into it at all anymore. There's a class at the college near by that is for manual transmission rebuilding. So if you get lost there's someone to help your ***. I was thinking about taking it just so I could learn some **** but decided against it in the long run.
Old Dec 16, 2011 | 05:22 PM
geohue's Avatar
This is the best thread I found for rebuilding the CRX Tranny, take a look, great pics
http://www.gassavers.org/showthread.php?t=359
Old Dec 21, 2011 | 12:40 PM
geohue's Avatar
Just bought the BK326WS kit as a Christmas gift to myself. Will take apart the CRX HF tranny and roast marshmellows by the fireplace..
brlabrune
Feb 23, 2009 12:37 PM
Stoich
15
Sep 21, 2005 05:44 PM
crxdevelop
Feb 24, 2003 09:47 PM
squirrel
Feb 19, 2003 09:12 AM
kim_2_da_chee
16
Feb 5, 2003 01:12 PM
