4th gen civic people-what offset?
I had 16x7 +40 for my daily driving wheels and 15x6.5 +38 for my track wheels, neither rubbed
I thought the Atech finalspeed wheels were +43 offset
http://www.esses.us/smw/info/fswh.htm
I was actually wondering how well these wheels fit, as I am also looking into getting a set
woops, ur right. they are +43. i immagine if anything they will rub on the inside. nothing a spacer wouldnt fix. but id like to know for sure.
-spenc
-spenc
just got an e-mail from Mr. Redshift himself and he says that +43 is actually the ideal offset. so ill be picking up a set of A-Tech Final Speed FS-05.
-spenc
-spenc
Yes, +42 or +43 in a 15x7 is the ideal offset. You won't get rubbing anywhere unless you subtract a lot of camber out of the rear, then will need to roll the fender a little.
I've used everything from 15x7 +43 Aguzzes to 15x6.5 +30 SSR's to 14x7 +28 Panasports on EF's. Currently we use 15x7 +35 Volks with 5mm spacers in front and 3mm spacers in the rear. No rubbing, but then again we're not making u-turns or doing extreme parking, and we've also rolled fenders front and rear.
KashMillien
Aug 19, 2015 07:12 PM
