B16 header vs. ITR header
Old Oct 2, 2003 | 03:41 AM
Jdmbsixteen's Avatar
Default b16 header vs. R header
I have a oem b16 header right now and also have a type R was wondering if there was a significant difference in the flow of the type R vs the b16?
Old Oct 2, 2003 | 07:21 AM
Default Re: b16 header vs. R header (redcivsi)
bump
Old Oct 2, 2003 | 08:45 AM
ITRacer121's Avatar
I assume you are talking of the exhaust mani folds? or are you talking of an after market header?) they should be diff.
Old Oct 2, 2003 | 09:48 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcivsi &raquo;</TD></TR><TR><TD CLASS="quote">I have a oem b16 header right now and also have a type R was wondering if there was a significant difference in the flow of the type R vs the b16?</TD></TR></TABLE>
There is a slight difference. Whether or not it's worth your time to get under the car and swap them is something you have to decide for yourself. Keep in mind that, if you don't also have the ITR cat., the manifold will not bolt-on.
Old Oct 3, 2003 | 06:30 AM
Default Re: b16 header vs. R header (Padawan)
bump for one more opinion
Old Oct 3, 2003 | 08:05 AM
Padawan's Avatar
Darth ModerVader
It wasn't really an opinion. I swapped a stock ITR manifold onto our Si, and I compared the two before I did it. The upper portions of both manifolds are completely identical. The lower halves, as I said, are very slightly different. The performace difference is also very slight, though I think some of it can be attributed to the ITR's slightly better-flowing cat, not just the manifold itself. If you're bored and it is free (as was my case), then sure, try it out. However, if you're paying for it, or if you aren't in the mood to wrestle with cat. bolts for a minimal power gain, then you probably shouldn't bother.
Old Oct 3, 2003 | 09:21 AM
GokuSSJ4's Avatar
why not upgrade to a 4-1 jdm header , then it will be worth it . or the 96 itr jdm header which is a 4-2-1 design with a 2.5' collector
Old Oct 13, 2003 | 07:30 PM
Default Re: b16 header vs. R header (GokuSSJ4)
I think that 96 is really heavy.
Old Oct 13, 2003 | 08:26 PM
yakitori's Avatar
from what I hear you lose torque on a b16 with the type r exhaust manifold
Old Oct 13, 2003 | 08:47 PM
Default Re: b16 header vs. R header (yakitori)
really?
umair
Oct 13, 2008 07:21 PM
Enta
Feb 23, 2007 06:39 AM
WhiteVX
Jun 15, 2006 06:43 AM
T3k C
Mar 30, 2006 01:17 PM
92'gsrhatch
Aug 22, 2003 12:25 PM
