CTR in a CRX OBDO which Ecu to use???
If i was to put a ctr in a crx which already has a b16a in it, utilizing obdo injectors,and distributor which ecu do i use? stock pr3(which i have?) or do i need to get it chipped or what. any advice would be helpful. thanx
You have to use the PR3 or PWO ECU.
It will be perfectly fine. Just go to a dyno after you install the engine and make sure the A/F ratio is OK.
I have a chipped (Mugen) PR3 ECU runing my B18C5 and it makes more HP than the OBD1 B18C5's out there.
