Help: Place Racing Crossmember Install
ok , i have a 1991 Civic Si hatch..... Bought a PR crossmember and just wondering how hard it is to install....
Just trying to get a feel of process of the install before i go and start wrenching...
Thanks
its very simple
remove the 4 bolts holding in the stock xmember 2 on each side
it should drop down and hang on the radius rods
remove the radius rod nuts
it will slide out then
next remove the factory tow hooks 2 bolts
then slide the PR xmember into the rods dont forget the bushings
hand tighten but dont snug them on yet
raise up the xmember install the 4 bolts but dont tighten them all the way just get them threaded
once its all lined up tighten down the xmember then the rods
DONE
DONE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast »</TD></TR><TR><TD CLASS="quote">
Thanks
It's the same as the stock one, very easy, but you have to remove your stock tow hooks to make it fit better.
Thanks
</TD></TR></TABLE>It's the same as the stock one, very easy, but you have to remove your stock tow hooks to make it fit better.
dont forget to get an alignment..... i put on the crossmember thinking it had the exact same placement as stock, then put on new tires and within a month and a half the outside edge was bald due to toe in.
its not a hard install though, jsut do what was said above
SuicideSlide
Oct 10, 2003 12:55 PM
