Help: Check engine light came on
Old Oct 1, 2003 | 07:06 PM
HybridGSR1's Avatar
Default Help: Check engine light came on
as i was driving today my check engine light came on.. idle was at a constant 1200rpm.. car stil drove fine.. after i shut it off for 2 hours start it back up.. check engine light went away.. idle still funny.. (always did) .. what would this be? does the idle control valve set off check engine light? does a lot of driving under hot heat cause this? err.. any help would be appreciated
Old Oct 1, 2003 | 07:08 PM
vtec.dc2's Avatar
Default Re: Help: Check engine light came on (HybridGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">as i was driving today my check engine light came on.. idle was at a constant 1200rpm.. car stil drove fine.. after i shut it off for 2 hours start it back up.. check engine light went away.. idle still funny.. (always did) .. what would this be? does the idle control valve set off check engine light? does a lot of driving under hot heat cause this? err.. any help would be appreciated</TD></TR></TABLE>
make sure no conenctors are loose.. like on top of manifold, read the code.. reset ecu.. see if it comes back, then take it from there
Old Oct 1, 2003 | 11:26 PM
HybridGSR1's Avatar
Default Re: Help: Check engine light came on (vtec.dc2)
anybody else?
Old Oct 2, 2003 | 10:34 AM
AamirCWITR's Avatar
cant help with out a code
Old Oct 2, 2003 | 12:44 PM
Smitdog's Avatar
Default Re: Help: Check engine light came on (AamirCWITR)
Sounds stupid but..... always make sure to click your gas cap at least 4 times. CEL's will come an go if u do not tighten the gas cap each gassing. Just a thought.....
Old Oct 2, 2003 | 04:58 PM
K20DC2R's Avatar
Default Re: Help: Check engine light came on (Smitdog)
sounds like an intermittent problem. thats why the cel didnt stay on. might be somthing simple. its not the gas cap cause the cel would store a code and not go away. its one of thoes weird incdents. nothing to worry about if it was the cel would stay on no matter if you turn off ur car.
Old Oct 2, 2003 | 05:02 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Help: Check engine light came on (VtecWhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecWhore &raquo;</TD></TR><TR><TD CLASS="quote"> its not the gas cap cause the cel would store a code and not go away. .</TD></TR></TABLE>
true. Give a code and maybe someone can help. just break a paper clip off and shove it in the blue thing off the ECU Or in Dave's case, use a fork
Old Oct 6, 2003 | 07:29 PM
HybridGSR1's Avatar
Default Re: Help: Check engine light came on (RealTypeR)
checked the code.. seems to be the TPS on the intake manifold..anyone have any ideas on how to fix this problem? cleaning or getting a new one?
Old Oct 6, 2003 | 07:32 PM
vtec.dc2's Avatar
make sure its not loose.. reconnect it.. reset ecu.. maybe it won't come back.
Sick CiviC EX
Honda Civic (2001 - 2005)
Oct 18, 2009 03:13 PM
bassrocker521
Feb 20, 2008 05:51 PM
gtec28
May 18, 2007 07:13 AM
lanojp1
Nov 25, 2004 08:53 PM
