Cams B16 or B18 on a B18head
this was something that i came across and saved but im not sure how accurate it is.
Recently I was looking for a good cam set for the application I am currently looking for and found a number of different lists for cam specs. The Japanese standard for measuring cam specs is @1mm which is, unfortunately, different from what some American brands like to measure at. I went through all the specs I had and converted them all to @1mm (except 3 I haven't done yet). This lets you do a much more accurate side-by-side comparison. I know there are a few other brands available (ZEX is one I just didn't put in, although I did know about it). If anyone knows any specs for sure that I have not included, please post and I will update the list!
ALL listed at @ 1mm! <IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/emthup.gif" BORDER="0">
Integra GS-R
Int-230 dur. / 10.6mm lift
Exh-227 dur. / 9.4mm lift
Civic Si '99 Spec
Int-240 dur. / 10.7mm lift
Integra Type-R Pre '99 Spec
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R
Int-243 dur. / 11.5mm lift
Spoon Sports
Int-256 dur. / 11.5mm lift
Exh-245 dur. / 11.1mm lift
Toda Spec A
Int-250 dur. / 11.6mm lift
Exh-240 dur. / 11.2mm lift
Toda Spec B
Int-255 dur. / 12.0mm lift
Exh-245 dur. / 12.0mm lift
Toda Spec C
Int-255 dur. / 12.5mm lift
Exh-255 dur. / 12.5mm lift
Toda Spec D (Estimated)
Int-265 dur. / 12.9mm lift
Exh-275 dur. / 11.9mm lift
Toda VTEC Killer
Int-265 dur. / 12.0mm lift
Exh-255 dur. / 11.5mm lift
JUN Type 1
Int-265 dur. / 10.9mm lift
Exh-268 dur. / 10.0mm lift
JUN Type 2
Int-267 dur. / 12.0mm lift
Exh-265 dur. / 10.9mm lift
JUN Type 3
Exh-265 dur. / 11.5mm lift
Skunk2 Stage 1
Int-252 dur. / 11.6mm lift
Exh-249 dur. / 10.8mm lift
Skunk2 Stage 2
Int-266 dur. / 12.3mm lift
Exh-262 dur. / 11.8mm lift
Skunk2 Stage 3
Int-270 dur. / 12.8mm lift
Exh-279 dur. / 11.8mm lift
Skunk2 Turbo (specs seem low? I called them, the VTEC now has less overlap, great for turbo <IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/emthup.gif" BORDER="0"> )
Int-230 dur. / 9.7mm lift
Exh-225 dur. / 8.9mm lift
Crane Stage 1
Int-243 dur. / 11.6mm lift
Exh-237 dur. / 10.8mm lift
Crane Stage 2
Int-248 dur. / 12.0mm lift
Exh-242 dur. / 11.6mm lift
Crane Stage 3
Int-254 dur. / 12.4mm lift
Exh-248 dur. / 12.0mm lift
Crower 400 (not converted yet)
Int- dur. / 10.7mm lift
Exh- dur. / 9.6mm lift
Crower 401 (not converted yet)
Int- dur. / 11.3mm lift
Exh- dur. / 10.5mm lift
Crower 401T (not converted yet)
Int- dur. / 11.8mm lift
Exh- dur. / 11.3mm lift
Crower 402A
Int-232 dur. / 11.8mm lift
Exh-228 dur. / 11.8mm lift
Crower 402
Int-237 dur. / 11.8mm lift
Crower 403
Int-246 dur. / 12.0mm lift
Exh-238 dur. / 11.8mm lift
Crower 411T
Int-242 dur. / 11.8mm lift
Exh-238 dur. / 11.3mm lift
Crower 412
Int-260 dur. / 11.8mm lift
Exh-252 dur. / 11.8mm lift
Crower 413
Int-269 dur. / 12.0mm lift
Exh-258 dur. / 11.8mm lift
Enjoy! <IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/emthup.gif" BORDER="0">
also this is where those pictures are from:
http://ff-squad.com/VtecCams.htm
and these are some more cam specs:
http://www.allmotorhonda.com/t...s.htm
Integra GS-R
Civic Si '99 Spec
Spoon Sports
Toda Spec A
Toda Spec B
Toda Spec C
Toda VTEC Killer
JUN Type 1
JUN Type 2
JUN Type 3
Skunk2 Stage 1
Skunk2 Stage 2
Skunk2 Stage 3
Crane Stage 1
Crane Stage 2
Crane Stage 3
Crower 402A
Crower 402
Crower 403
Crower 411T
Crower 412
Crower 413
