b16 acceleration issue.
well its kinda weird I have a b16a in a 90 ef dx and I just finallyh got all the other o2 installed to be 2 and wired correctly to the ecu and runs fine no more hesitation at half throttle could not be anymore happier. but the thing is sometimes, when I floor it its like not how itss supose to be then all of a sudden a sudden jolt that makes it faster that kinda throws u back in ur seat if u not pay attention kinda like its trying to catch up to where the throttle point is acctually at, if that makes sense.... oh well thanks in advanced.
really the pin goes bad? the knock sensor is hooked up. and it doesnt throw the cel as soon as I turn on, like the cel comes on after I move it a little or rev a little, high Ithink it has something to do with vibrations because of have the hasport motor mounts and they are stiff as hell.
nope because when my friend wired up my o2s corectly monday, he said the knock wire was connected.
the shop that did my swap got lazy and just put one o2 sensor in and ran a wire from it to the secondary o2 on the ecu
... so i had to save up for my friend to rewire it and shyt....
but will my knock sensor cel make me loose some of my performance? I just replaced the wires, with OEM TYPE R wires from acura..... they really didnt do anything beside new injecters new valve cover gaskets and new headgasket, should I do anything else to make my b16 run better? maybe a cap, and rotor? new spark plugs? any help would be great.
JDM EJ2
37
Jul 30, 2008 08:18 PM
