Which ECU should I get ??
Old Oct 1, 2003 | 03:19 PM
vtec_head's Avatar
Default Which ECU should I get ??
Hello,
I'm wondering which ECU I should get for my '88' CRX Si which has a ZC enginge installed. There's a guy on the board that's selling a ZC ecu for $125 should I get it?? or should I just buy a '89' Teg ecu for about $150 from a used parts place.
Does anyone know which ECU will give me better performance? ZC ecu or the '89' Acura Integra ecu.
thanks in advance......
Old Oct 1, 2003 | 04:00 PM
APEX CRX's Avatar
I'm pretty sure the zc ecu will be better as I think it has better mapping for fuel and slightly hight rev limit
Old Oct 1, 2003 | 04:27 PM
Loaded Butane's Avatar
Default Re: Which ECU should I get ?? (vtec_head)
I'd get the ZC ecu. Be aware that it has a speed limiter around 112 MPH.
Old Oct 1, 2003 | 04:58 PM
vtec_head's Avatar
Default Re: Which ECU should I get ?? (Loaded Butane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane &raquo;</TD></TR><TR><TD CLASS="quote">I'd get the ZC ecu. Be aware that it has a speed limiter around 112 MPH.</TD></TR></TABLE>
How much different is a '89' Teg ecu ??? Is the speed limiter higher than the ZC ecu of 112 mph ???
A guy here on the board just offered me one for just $50 I guess if it's legit then I should go for it right????
Help me out guys....
Old Oct 1, 2003 | 05:06 PM
As far as I know the Teg ECU has no speed limiter. I had one running my ZC for a while before I went with a Chipped PM6.
$50 is a pretty good price for a Teg ECU. Make sure its a 88-89 model if this is going in a 88-91 model.
Old Oct 1, 2003 | 08:14 PM
jlicrx's Avatar
we have run both the PG7 (integra) and PM7 (ZC) and find no difference at all in how the car runs - get the integra - fuel cut-off is same on both at 7500
Old Oct 1, 2003 | 09:36 PM
91civicDXdude's Avatar
$50 is steep. I can get ECU's all day long for $25 at U-Wrench-It in Kansas City.
Old Oct 2, 2003 | 05:59 AM
Phatwhippin_CRX's Avatar
Default Re: (91civicDXdude)
get the ZC ECU, it's the correct ECU for the engine..... I've seen many a teg-ecu'z ZC cars have lots of problems...... running rich and frying dizzys......
Old Oct 2, 2003 | 07:55 AM
pirocrxracer's Avatar
i have a sohc zc in a hf with the orginal ecu. The hf ecu has been programed by jet but it still floods and doesn't run exactly right.
Old Oct 2, 2003 | 07:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">get the ZC ECU, it's the correct ECU for the engine..... I've seen many a teg-ecu'z ZC cars have lots of problems...... running rich and frying dizzys......
I dont see how that would happen. The PG7 ECU should run a little rich on a SOHC engine, seeing as how its made for a higher horsepower DOHC engine. I know i'll probably get flamed for this, but you know essentially, the D16A1 and ZC are *VERY* similar. The PM7 would be the ideal ECU, but if you cant get a hold of it, a PG7 will still rip major ***.
South Bay Surfer
Feb 29, 2004 12:10 PM
muskrat
Oct 10, 2002 07:09 PM
nihkon
Aug 2, 2002 11:11 AM
jdm_ef9
Jan 8, 2002 09:30 PM
REDBARON
Oct 15, 2001 06:21 PM
