Ls whp?
Old Oct 1, 2003 | 12:59 PM
teg2000gs's Avatar
Default Ls whp?
what dyno results have u guys gotten on all motor b18b's?
Old Oct 1, 2003 | 01:28 PM
patmcd's Avatar
Default Re: Ls whp? (teg2000gs)
the most ive seen dynos for are in the 170ish range. I suspect that you might be able to get up to 190, but it wouldnt be streetable
Old Oct 1, 2003 | 01:35 PM
Xumarius's Avatar
Default Re: Ls whp? (patmcd)
124 whp on stock b18b
Old Oct 1, 2003 | 02:27 PM
91tegrals's Avatar
highest i have seen personaly would be 168 not tuned and was a mild set up so i could see 180 -190 being possible..
Old Oct 1, 2003 | 03:18 PM
BlueTeg's Avatar
Default Re: (91tegrals)
123 whp, 116 tq with I/H/E
Baseline Run (Blue) = aem cai, comptech header, 2.25" carsound cat, comptech exhaust = 132 whp, 121 tq
Dyno Run 007 (Red) = same setup as above + Crower 403 cams, Crower valve springs, B&M fpr set at 40psi @ idle, aem cam gears (intake +1, exhaust -1), SAFC 150 whp @ 6500 rpms 125 lb/ft tq @ 5300 rpms
Old Oct 1, 2003 | 03:38 PM
ggangtong81's Avatar
Default Re: (BlueTeg)
how can u have 180 whp on ls without boosting?? if i put i/e/h, and change cams with cam gears, and an upgraded fuel system, with fine tuning, would i get 180 whp?
Old Oct 1, 2003 | 03:46 PM
BlueTeg's Avatar
Default Re: (ggangtong81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ggangtong81 &raquo;</TD></TR><TR><TD CLASS="quote">how can u have 180 whp on ls without boosting??
It would be pretty tough to hit 180 on 1.8L
You can 165-175ish w/ Crower 404 or 405's and 11+ CR
Depends on what cams....but without increasing CR you won't see big gains (150+ whp on an LS)
Old Oct 1, 2003 | 05:28 PM
91tegrals's Avatar
it would take some big costum grinds and a lot higher compression than 11.1 but i think its possible just wont be able to drive it on the streets..
Old Oct 1, 2003 | 05:39 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Depends on what cams....but without increasing CR you won't see big gains (150+ whp on an LS)</TD></TR></TABLE> so youre saying that with an increase in compression you'll get 15-25 more whp than you did with your mods? (i/h/e/c/cg)
Old Oct 1, 2003 | 05:45 PM
BlueTeg's Avatar
Default Re: (Threatcon13)
I've seen two dyno's of guys that make ~165whp with higher CR.
Example:
B18b engine, DC Sports short ram intake, JDM ITR 4-1 header, 2.25" Carsound cat, 2.25" Thermal cat-back, Wiseco pistons, Eagle rods, 11.3 CR, Crower 62403 cams, ported and polished head, 3 angle valve job, Skunk2 im, 64mm TB, UR crank pully, pyr chipped ecu, fuel and cam gear settings are untuned
^ all that in civic hatch w/ jdm itr tranny!!
Nearly 160 whp:
Tech-tom ECU (better fuel and ignition mapping) fuel cut-off @ 8K
Crower 403 cams
Crower titanium valve springs
Crower titanium retainers
Skunk2 Cam gears
Skunk2 intake manifold
AEM Fuel Rail
B&M adjustable FPR
OB throttle body (65mm)
AEM CAI
Airmass/Holley Header
RSR full cat-back with test pipe (2.25ÂE
balanced bottom end
0.25mm oversize P73-a0 pistons (USDM ITR)
knifed and balanced crank
This guy runs roughly 10.3 CR w/ those itr slugs.
Modified by BlueTeg at 6:57 PM 10/1/2003
Old Oct 1, 2003 | 06:06 PM
JCushing's Avatar
theres guys out there puttin down over 200whp with 84mm bores
those dynos are impressive since they all seam to use those weak 403 cams
Old Oct 1, 2003 | 06:23 PM
Rah Rah's Avatar
Default Re: Ls whp? (JCushing)
118 hp 118 tq before the snail
Old Oct 1, 2003 | 07:01 PM
SuzukaBlueAP2's Avatar
Default Re: Ls whp? (Rah Rah)
I hit 144.3 with stock intake, DC 4-2-1 header, test pipe, Tanabe Racing medallion exhaust, 11lb flywheel, 50psi fuel pressure, and red line 10w-30 motor oil. I had just over 100k miles on the car and was in serious need of a valve adjustment. They were so outta whack that when letting the car down-rev after tiaking it to redline it would seriously shoot up to 5 foot fire ***** out the exhaust. That's no joke either. I was quite impressed.
Old Oct 1, 2003 | 07:33 PM
BlueTeg's Avatar
Default Re: Ls whp? (urbanracer98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 &raquo;</TD></TR><TR><TD CLASS="quote">
I had just over 100k miles on the car and was in serious need of a valve adjustment. They were so outta whack that when letting the car down-rev after tiaking it to redline it would seriously shoot up to 5 foot fire ***** out the exhaust. That's no joke either. I was quite impressed. </TD></TR></TABLE>
Would you mind posting your dyno sheet? 144whp on an i/h/e LS?? [rolls eyes]
Perhaps the FnF fireballs that you were shooting were because you're running hog rich at 50psi. I dunno just a guess. You better lay low on the fireball shooting.....next thing you know your under-chassis will be glowing neon and you'll be racing Tyrese for "slips"
Modified by BlueTeg at 10:09 PM 10/1/2003
Old Oct 1, 2003 | 08:43 PM
riceball777's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 &raquo;</TD></TR><TR><TD CLASS="quote">I hit 144.3 with stock intake, DC 4-2-1 header, test pipe, Tanabe Racing medallion exhaust, 11lb flywheel, 50psi fuel pressure, and red line 10w-30 motor oil. I had just over 100k miles on the car and was in serious need of a valve adjustment. They were so outta whack that when letting the car down-rev after tiaking it to redline it would seriously shoot up to 5 foot fire ***** out the exhaust. That's no joke either. I was quite impressed. </TD></TR></TABLE>
i call bs
Old Oct 1, 2003 | 09:11 PM
MikeTV
Guest
Posts: n/a
Default Re: Ls whp? (Xumarius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xumarius &raquo;</TD></TR><TR><TD CLASS="quote">124 whp on stock b18b </TD></TR></TABLE>
124 sounds pretty high for a stock b18b....I think between 110-120 sounds more realistic
Old Oct 2, 2003 | 04:43 AM
Alexander's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">I've seen two dyno's of guys that make ~165whp with higher CR.
Example:
Holy crap did you guys even look at the torque line on this graph? Thats nuts! (for an integra LS)
I'm jealous
A.
Old Oct 2, 2003 | 05:57 AM
94ls's Avatar
stock ls is around 116-118 whp... no all motor b18b with just bolt-on's is gonna come close to 180whp, even with higher cr, cams, upgraded fuel system, bigger tb, still...not gonna hit 180whp..sorry man.. ls/vtec may come close but FI is the only way u gonna get those #'s at the wheels. if you know what you're talking about im sure u can agree
Old Oct 2, 2003 | 07:30 AM
JCushing's Avatar
Default Re: Ls whp? (94ls)
sure it will, big cams like 405a's or crane # 20 ported and high compression with a good intake/exhaust setup. i know of 2 people on here that have 84mm non vtec that hit 200+hp so 180 for an ls isnt out of line
Old Oct 2, 2003 | 02:48 PM
BlueTeg
Sep 23, 2004 06:45 PM
turbolag98
Nov 7, 2003 06:56 PM
Audipwr1
Mar 19, 2003 04:24 PM
G2Integrity
Jul 16, 2002 08:35 AM
OneFastLS
Apr 24, 2002 06:48 PM
