20x8 slicks to small?
Old Oct 1, 2003 | 11:31 AM
ranta18's Avatar
Default 20x8 slicks to small?
Setup:
210 whp H22 Civic
2200 lbs w/ driver
MT 20x8 14" slicks
Are these to small? Should I use a 22x8? With 205/50R15 tires I'm crossing the line in 4th at almost 7K rpm. That tire is 23" diameter. Should I go with the 22" slick?
Old Oct 1, 2003 | 12:03 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: 20x8 slicks to small? (ranta18)
way too small
Old Oct 1, 2003 | 01:09 PM
pro1342's Avatar
I think they are too small, but whatever it takes to hook up......
Old Oct 1, 2003 | 01:23 PM
Gravy's Avatar
Default Re: (pro1342)
yeah you should at least use a 22x8
Old Oct 1, 2003 | 08:17 PM
T4eg's Avatar
way to small....i would look into the 22.5 x8x13
Old Oct 1, 2003 | 10:14 PM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">Setup:
210 whp H22 Civic
2200 lbs w/ driver
MT 20x8 14" slicks
Are these to small? Should I use a 22x8? With 205/50R15 tires I'm crossing the line in 4th at almost 7K rpm. That tire is 23" diameter. Should I go with the 22" slick?</TD></TR></TABLE>
Let's do this right if you give me your Overall FD gear and what size is your gear in 4th and what speed and rpm you want to be @ threw the traps, IM me and we can cook something up. Good Luck John@M&H-Hashim's
Old Oct 1, 2003 | 11:32 PM
ranta18's Avatar
Default Re: 20x8 slicks to small? (SlicksMH)
If you use the formula to figure it, its looks like this:
Speed in 4th gear at 8000 rpm is
(8000 rpm * 5.2333 ft) / (1.034 * 4.266 * 88) = 107.86 mph
If I shift at 7900 instead it drops it to 106.51 mph
If I shift at 7800 it drops it to 105.16 mph
The question is, will I be going that fast at the 1/4 mile?
Old Oct 2, 2003 | 01:33 PM
kwik93si's Avatar
I'm using the 23" MH slicks now and they're too big for my setup...1950lbs w/ me, 203whp and 158tq, 12.4's @ 106.8mph. I'm switching back to 22's this weekend...i should run low 12's w/ higher mph. 20's will be way too small...you'll be well into 5th gear with those.
Old Oct 2, 2003 | 02:19 PM
SlicksMH's Avatar
Hi (ranta18) You have a 4.41 FD in 4th gear, here is my # . You use a 20" slick @ 7100 rpm you will be going 95 mph, now @ 7500 rpm is 101 mph now @ 8000 rpm is 108 mph. I am close with in 2-mph. Now the ? is the HP you have will the 20" slick hold up and not spin, it just depends on how you set the car up. So you have the 20" slicks so put them on and find out and report back with us and let us know how you did. GOOD LUCK and to you. John@M&H-Hashim's
Old Oct 3, 2003 | 02:10 AM
Mista Bone's Avatar
D Tranny Guru
easy way to figure............
http://nonsense.netfirms.com/speed.html
I've been using this layout for 21 years now.
MT 20x8x14 slick is only good to 200 hp with a stock or CF DF clutch. A more agressive clutch will just result in wheel spin.
b18cej2
Apr 29, 2009 01:57 PM
RTW DC2R
Sep 19, 2006 03:44 PM
dragaholic
Aug 11, 2006 06:39 AM
kun3racer
Jul 26, 2004 06:37 PM
RacerStev
Apr 21, 2004 07:36 PM
