Installing new head unit in 5th gen prelude..Help!!
Hey, just bout a head unit for my 5th gen prelude and I was looking to install it myself....I went to best buy near my place to ask if they would install it, the guy said do it urself it'll be cheapr and take 5 minutes...sooo if anyone has any info on how to do this, please shareeee..
".:s h a w n D:. (9:52 AM 10/1/2003): to install your headunit you need the adapter harness for your make/model car its like 10-15 bucks connect the color wire from the adapter harness to the corresponding colors of the new head unit attatch the harness to the stock one that your car has and your set!!"
thats it?..greattt...one thing do I need to get any extra wires or wiring harness, orrr can i use the same connects used to connect the stock unit on the new one?
do it the right way.... get some bell caps (about 15) and zip ties. cap all of the wires, even the ones you're not using so they don't ground out. As far as the lude, just pop off that trim ring around your cd player and pocket with a small flathead screwdriver, but be careful not to scratch it. then, you'll see 4 8mm bolts, and undo those. self explanitory from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic@7psi »</TD></TR><TR><TD CLASS="quote">do it the right way.... get some bell caps (about 15) and zip ties. cap all of the wires, even the ones you're not using so they don't ground out. As far as the lude, just pop off that trim ring around your cd player and pocket with a small flathead screwdriver, but be careful not to scratch it. then, you'll see 4 8mm bolts, and undo those. self explanitory from there.</TD></TR></TABLE>
Bah, here's how you do it. Get the harness, either from BB or Circuit city. If it's a brand either carries you should be able to get a harness that goes right from the radio to the car, or from the radio to universal and then universal to car. Also get the dash kit (such as the AMI HON-K828). To remove the old radio, just pop the back trim around the radio area off. It's tuff some times and the clips like to fall back down into the dash. remove the 4 screws and take old radio out. Put kit together, and mount radio in it, put dash back together, put harness into dash, take kit and plug harness into radio (antenna too!) and then stick the kit into the spot where the old radio was. Bingo, you're done.
GSR-EG-92
Audio / Security / Video
Jun 15, 2009 11:52 AM
justint
May 19, 2006 04:51 AM
pinoyboiwonder
12
Feb 24, 2006 05:45 PM
civicEXtreme
Jan 30, 2006 09:45 AM
