Low beams take a while to turn on...
Old Oct 1, 2003 | 07:38 AM
7rrivera7's Avatar
Default Low beams take a while to turn on...
But the high beams come on instantly. I usually have to wait about 10 secs after switching them on before they light up. Is this a relay problem?
Old Oct 2, 2003 | 04:12 AM
7rrivera7's Avatar
Default Re: Low beams take a while to turn on... (7rrivera7)
Anyone have a CRDX with this problem?
Old Oct 2, 2003 | 01:53 PM
Sikocivic's Avatar
I had the same thing happen to my 88 DX hatch. It got worse the colder it got. When it was below zero outside they would take 3 or 4 min to come on.
Old Oct 3, 2003 | 07:26 AM
7rrivera7's Avatar
Default Re: Low beams take a while to turn on... (Sikocivic)
Did you ever resolve it?
Old Oct 3, 2003 | 01:09 PM
Sikocivic's Avatar
NO. The guy I sold it to never found out what was wrong either
Old Oct 3, 2003 | 01:28 PM
beaslbob's Avatar
i have the same problem with my '91 dx sedan and havn't found a solution yet. i just run highbeams untill they heat up.
Old Oct 4, 2003 | 09:52 AM
Donkey85's Avatar
i have this same probem too but only when its cold out the lows wont come on for 30 seconds and the highs wont come on till the lows do. i have a 89 dx hatch.... if somebody could figure it out that would be a great help to all of us thanks in advance
Old Oct 4, 2003 | 11:02 AM
MrTodd's Avatar
Default Re: (Donkey85)
Uhhh... Did you guys replace the low-beam bulbs?
Old Oct 4, 2003 | 11:35 AM
7rrivera7's Avatar
Default Re: (MrTodd)
Can you explain why the bulbs would take long to turn on?
Old Oct 4, 2003 | 11:37 AM
MrTodd's Avatar
Default Re: (7rrivera7)
I don't know, but my CRX had a similar issue. The passenger side low-beam headlight sometimes would turn on, and other times it wouldn't. I replaced the bulbs and it works perfectly now.
New bulbs aren't expensive, it's definitely worth a shot.
Old Oct 4, 2003 | 11:38 AM
Donkey85's Avatar
why would we need to replace the low beam bulbs if they still work?, they just take 30 seconds or so to turn on
Old Oct 4, 2003 | 11:51 AM
MrTodd's Avatar
Well, I figured since you guys took the time ask on this forum you might want an answer - so there is your answer. Get new bulbs.
Old Oct 4, 2003 | 12:02 PM
Project91CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">why would we need to replace the low beam bulbs if they still work?, they just take 30 seconds or so to turn on</TD></TR></TABLE>
Lets put it this way.. Lets say you have to take 10min to start your car. But it still works..
It's like me telling you "Why would you need to fix it if it still works"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">
New bulbs aren't expensive, it's definitely worth a shot.</TD></TR></TABLE>
Just like what MrTodd said. It's worth a shot.
Old Oct 4, 2003 | 01:08 PM
7rrivera7's Avatar
Default Re: (Project91CRX)
I'll replace mine and let you all know if it solves my problem!
Old Oct 5, 2003 | 07:02 PM
Donkey85's Avatar
alright let us know...... my bulbs arnt even that old so i'm not replacing **** till they burn out... i just wanted to know if anybody had a real answer to the problem
Old Oct 5, 2003 | 07:08 PM
90Sicvic's Avatar
I have a 90 Si, I seem to have this problem but different. I think it is in the switch actually. If I turn them on all the way forward they will not come on. I have to turn the switch back a little. Maybe you guys should try to wiggle the switch a little a little to see if things happen? just a thought.
Kanjo
Mar 4, 2015 09:05 PM
projectpd
Apr 5, 2007 09:38 PM
wsigstedt
Jan 9, 2004 10:07 PM
EF-9SiR
Feb 7, 2003 10:45 PM
