Is 700 for an zex kit with instal too much?
Old Oct 1, 2003 | 07:10 AM
ramz7887's Avatar
Default Is 700 for an zex kit with instal too much?
I want to know It seems like 200 for instalation is a little high plus i have the zex air filter so i don't have to tap the tb.
Old Oct 1, 2003 | 07:38 AM
1SIKCRX's Avatar
Default Re: Is 700 for an zex kit with instal too much? (ramz7887)
yes that is abit too much!!! which zex kit are you getting? dry? wet? ect...?
i have the zex dry kit. and it was an easy install. i only incounted 1 problem! which wire to splice into the TPS! there was 3 wires and it was 3:30am so i couldn't get ahold of anyone. so i took a guess at which wire it was. and i spliced into the RED wire!!! i was right!!!!
if you really do not want to do the install yourself. then if i was you i wouldn'y pay no more than $75 for the install!!!
maybe someone around where you live can hook you up on the install!!!
just my .02 cents!!!
Old Oct 3, 2003 | 10:54 AM
egcivic94's Avatar
yes I agree $200 is a little high, you can do it your self just read the instuctions, I hooked mine up in about 2 hours.
Old Oct 3, 2003 | 10:59 AM
Trak_Day's Avatar
New User
If you have the ***** to run nitrous why not have the ***** to install it man...The install is more exciting than flipping the switch anyways...plus if you install it you will know how to fix something if anything ever happens with the nitrous kit itself.
I have installed 2 ZEX kits and it is defiantely not worth paying anyone to do it. It is very simple if you have little to no knowledge in cars.
Read through the direction and then decide what you should do. And shop around on the internet for a better price on the kit. and i suggest getting a purge kit also rather than spending the money on install.
Old Oct 3, 2003 | 11:03 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (DroppedGSR)
sound like someones charging you 75 an hour
Old Oct 3, 2003 | 11:29 AM
twkdCD595's Avatar
Default Re: (HybridcivicLS-T)
WAY to much...
install it yourself and learn what your doing first hand.
Old Oct 3, 2003 | 11:35 AM
quikB18B's Avatar
Default Re: (twkdCD595)
Way too much
Like they said install yourself and spend the $200 on something worthwhile, Purge, bottle heater
Old Oct 3, 2003 | 11:43 AM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DroppedGSR &raquo;</TD></TR><TR><TD CLASS="quote">if you install it you will know how to fix something if anything ever happens with the nitrous kit itself.
exactly what i was thinking. my friends and i installed my NOS kit in about 2 hours, and had to deal with mis-matched wiring, and fried relays that were given to us. i shorted out a wire one time, and since i did the install i knew exactly where the problem was.
sfwdcrx
Sep 4, 2007 01:53 PM
vtecftw
Apr 15, 2007 05:45 PM
06rallyredsi
Honda Civic (2006 - 2015)
Dec 24, 2006 07:12 PM
BlownVR
May 16, 2004 01:36 PM
G3-GSR
Oct 18, 2001 09:00 PM
