ZC Headlights in 1991 CRX...
Old Sep 30, 2003 | 09:22 PM
SIINSI's Avatar
Default ZC Headlights in 1991 CRX...
I did a search but came up empty. Hope you guys can help I just ordered a set of ZC Headlights. I was told that they need to be modified slightly to fit. I have a 1991 CRX Si. Does anyone know exactly what needs to be modified? Pics?
Thanks in advance!
Miguel
Old Sep 30, 2003 | 09:44 PM
crxgator's Avatar
Default Re: ZC Headlights in 1991 CRX... (SIINSI)
i think its just having to do with the one bulb system and thats it...
Old Sep 30, 2003 | 10:16 PM
CRX-RX's Avatar
Default Re: ZC Headlights in 1991 CRX... (crxgator)
Do they use US spec corner lamps or the japanese/european units?
Old Oct 1, 2003 | 04:39 AM
redzcstandardhatch's Avatar
something different
Default Re: ZC Headlights in 1991 CRX... (CRX-RX)
i'm pretty sure you use stock corners with them.
Old Oct 1, 2003 | 05:35 AM
markedOO1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-RX &raquo;</TD></TR><TR><TD CLASS="quote">Do they use US spec corner lamps or the japanese/european units?</TD></TR></TABLE>
..it really doesnt matter, as they're the same shape/size..
Old Oct 1, 2003 | 07:20 AM
SIINSI's Avatar
Thanks for the replies... So do the headlights need to be re-wired? I take it, it uses a different bulb? Any more info on this as well?
Thank again,
Miguel
Old Oct 1, 2003 | 07:33 AM
markedOO1's Avatar
the jdm si headlights use a dual filament bulb for the hi beams/lo beams, as opposed to the separate bulbs your system uses now... so..yes.
Old Oct 1, 2003 | 07:44 AM
Brewer's Avatar
Default Re: ZC Headlights in 1991 CRX... (markedOO1)
Hope this car comes out as nicely as your EK, Miguel. Good luck!
Old Oct 2, 2003 | 12:26 AM
CRX-RX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markedOO1 &raquo;</TD></TR><TR><TD CLASS="quote">
..it really doesnt matter, as they're the same shape/size..</TD></TR></TABLE>
Yes, on the outside, but where they attach to the headlight itself is totally different.
Old Oct 2, 2003 | 01:13 AM
d0nkeyxPunch's Avatar
Banned
Default Re: ZC Headlights in 1991 CRX... (BrewerHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewerHatch &raquo;</TD></TR><TR><TD CLASS="quote">Hope this car comes out as nicely as your EK, Miguel. Good luck! </TD></TR></TABLE>
werd
Old Oct 2, 2003 | 04:35 AM
markedOO1's Avatar
Yes, on the outside, but where they attach to the headlight itself is totally different. </TD></TR></TABLE>
do you mean to the car? or to the headlight? b/c they really dont literally attach to the headlight... I dont think.
Old Oct 2, 2003 | 05:04 PM
SIINSI's Avatar
So as far as fitment, are any modifications needed to be made to mount the lights themselves?
TIA
Miguel
Old Oct 2, 2003 | 05:40 PM
bryant's Avatar
They should bolt in just fine, on a '91 though your going to have to transfer the JDM headlight to the '91 USDM housing if you want to keep your '91 corners. The JDM bulbs are H4H's (some headlights have diffferent bulbs), but your 9006 set up will not work. You will need to wire your highs and lows together as the new JDM headlight is a single bulb instead of the like the USDM seperate high and low.
Old Oct 2, 2003 | 07:05 PM
SIINSI's Avatar
Default Re: ZC Headlights in 1991 CRX... (Bryant)
Sweet, thanks for the info, now I just have to hope that when they come, they have the H4H sockets attached
Thanks!
westherb
Jul 15, 2008 11:44 AM
EFin' Kyle
Aug 16, 2007 03:15 PM
Jonknee
Oct 27, 2006 04:51 PM
Civicboy
19
Nov 25, 2004 07:01 PM
88crxvtec
16
Jan 13, 2003 02:01 PM
