How do I take the bushings out?
Old Sep 30, 2003 | 06:22 PM
Renegade's Avatar
Default How do I take the bushings out?
What is the easiest way that I can do it myself or a local shop that take off for me?
thanks
Old Sep 30, 2003 | 06:34 PM
ragejed's Avatar
Default Re: How do I take the bushings out? (Renegade)
You should search....really. This has been covered.
-Propane torch.
Old Sep 30, 2003 | 07:12 PM
Tyteteg119's Avatar
Default Re: How do I take the bushings out? (ragejed)
It would have been easier just to say: U need a hydraulic Press. Take it to a machine shop they will know what to do.
Old Sep 30, 2003 | 07:20 PM
cr00klyn718's Avatar
Default Re: How do I take the bushings out? (Tyteteg119)
Take it to the shop and have it pressed out.
Old Sep 30, 2003 | 07:22 PM
all stock's Avatar
Default Re: How do I take the bushings out? (cr00klyn718)
propane torch - PITA
machine shop press - 10 minutes
Old Sep 30, 2003 | 08:03 PM
Tweakmeister's Avatar
Default Re: How do I take the bushings out? (all stock)
...just press them out.
Old Sep 30, 2003 | 08:41 PM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">propane torch - PITA
machine shop press - 10 minutes</TD></TR></TABLE>
should learn how to use a torch then.
propane torch = 3 mins
Old Sep 30, 2003 | 11:18 PM
Renegade's Avatar
that's a cool picture.
I rather look for a shop, faster less hassle.
Old Oct 1, 2003 | 03:42 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">What is the easiest way that I can do it myself or a local shop that take off for me?</TD></TR></TABLE>
a press is the correct way to remove that bushing. do yourself a favor and have it done right.
Q: what is wrong with the bushing in the picture?
Old Oct 1, 2003 | 05:23 AM
Big Teggie's Avatar
Another cheap effective way is to drill out all the rubber so the inner collar falls out. Then go back and cut the ring out that is left.
A torch works well too.
Old Oct 1, 2003 | 05:49 AM
Renegade's Avatar
Default Re: How do I take the bushings out? (Big Teggie)
the bushing is fine I am going with poly bushings.
Old Oct 1, 2003 | 09:54 AM
ragejed's Avatar
Default Re: How do I take the bushings out? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
Q: what is wrong with the bushing in the picture?</TD></TR></TABLE>
Correct way? Maybe the less hassle, and faster way. But also more expensive.
I would have never payed a shop to press out all the bushings when i replaced them with es. Sure it was time consuming, and I had to do more work then paying a shop....but it was a fun experience, and free.
Old Oct 1, 2003 | 02:12 PM
owen_the_soyboy's Avatar
LOL...
I took mine out with a big VICE and a pair of collars (sections of tubing) that were the right size.
really, a big vice and I was all set, even used that to install the poly's.
and I had a 15 ton hydraulic press at my shop, just dont need it for these specific bushings.
Old Oct 1, 2003 | 02:58 PM
ndtITR's Avatar
you def. need to either have 4 blow torches set up and like 3 days to do the bushing kit or everytime you cant get one out go to merlins....and get it blown out w/ an air hammer or pressed.
Old Oct 1, 2003 | 03:01 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (ndtITR)
I had to use a torch and a press since the bushings were seized
Old Oct 1, 2003 | 03:21 PM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndtITR &raquo;</TD></TR><TR><TD CLASS="quote">you def. need to either have 4 blow torches set up and like 3 days to do the bushing kit or everytime you cant get one out go to merlins....and get it blown out w/ an air hammer or pressed.</TD></TR></TABLE>
huh??!!??
Old Oct 1, 2003 | 06:56 PM
95excoupe's Avatar
Default Re: (ragejed)
I just did the bushings in my control arms we needed to use my friends airshizzle and a press, I couldnt imagine doing it any other way...
Old Oct 1, 2003 | 07:50 PM
743power's Avatar
Default Re: (95excoupe)
blow torch will get the rubber out, but there will still be the metal collar around the outside that you will have to hacksaw out. Take it to a shop, and they'll probably charge you a couple bucks or do it for free. . .
Old Oct 2, 2003 | 01:21 AM
Vitt1's Avatar
Default Re: (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">...Take it to a shop, and they'll probably charge you a couple bucks or do it for free. . .</TD></TR></TABLE>
I got quotes of $15 per arm from 2 different shops. I assume that was to install the new ones as well if necessary. So, 2 LCAs and 2 TAs = $60.
Old Oct 2, 2003 | 01:29 AM
1OPTION's Avatar
Agreed.
Old Oct 2, 2003 | 06:31 PM
743power's Avatar
Default Re: (Vitt1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vitt1 &raquo;</TD></TR><TR><TD CLASS="quote">
I got quotes of $15 per arm from 2 different shops. I assume that was to install the new ones as well if necessary. So, 2 LCAs and 2 TAs = $60.</TD></TR></TABLE>
time = money, and TA bushings = time, so $60 sounds like a good deal.
Old Oct 10, 2003 | 07:00 AM
Renegade's Avatar
Default Re: (743)
bushings are out $45 at speed merchant, and if anyone cares or may need it later, Motorsports techniques in Hayward would do it for $40.
Old Oct 10, 2003 | 07:04 AM
DarthLuder's Avatar
New User
torch.
Boostage
14
Jul 23, 2006 03:19 PM
I-VTECRX
Welding / Fabrication
10
Dec 31, 2005 04:28 PM
crxhf19
Feb 17, 2005 09:47 PM
iHATEspeedbumps.
Oct 23, 2004 04:10 AM
unknown2
May 18, 2004 01:50 PM
