alternator and belt are bad
i'm having a little trouble on figuring out how to get my belt off then my altenator, can anyone here give me a few pointers, also my car is a 89 crx si with a b16a1 swap if that helps. It just seems like a tight squeeze to get the belt and alternator out from. thanx for any help you guys can give
David
David
From: I told you to wait in the truck in Texas, United States
If the old belt is bad,just cut it in half..
try these links: http://www.crx.org/southcal/tech/alternator/
or
http://geocities.com/chipman_1....html
or
there should be an a bolt on top thats the adjuster bolt, then take a pry bar and pry the alternator toward the front of the car, this should loosen the belt, then u may or may not have to remove the axle to get the alternator out, just depends on how good u are in tight spaces
519[H]Si
May 25, 2004 09:25 PM
B2FiNiTY
14
Sep 24, 2003 01:17 PM
