HELP!!! Rebuilding recovered gs-r: steering lock doesn't work (ignition doesn't mount right)
Alrite,
I bought it as a salvaged theft recovery. The theives(
) broke off the ignition from the steering column and then took apart the ignition cylinder to start the car.
Problem is... when they broke the ignition apart from the steering column, they warped the metal sheath that surrounds the axle from the steering wheel, so now i can't mount it in such a way that the steering lock engages when i remove the key.
I'm getting the state salvage rebuild inpection soon, and don't know whether it will pass if you can move the wheels w/ no key in.
Also, if anyone has experienced this before, tell me what you did to fix it
I'm thinking if i take the metal cover to a machine shop or something, they can possibly warp it back into place?
) broke off the ignition from the steering column and then took apart the ignition cylinder to start the car.Problem is... when they broke the ignition apart from the steering column, they warped the metal sheath that surrounds the axle from the steering wheel, so now i can't mount it in such a way that the steering lock engages when i remove the key.
SoCalCivic498
Apr 20, 2015 08:37 PM
decent
Nov 7, 2005 11:10 AM
Tokyo_X-treme_Racer
Jul 6, 2005 09:59 PM
