What guages are most important 4 a 94 LS when adding a turbo
Old Sep 30, 2003 | 12:48 AM
crosswrench's Avatar
Default What guages are most important 4 a 94 LS when adding a turbo
I am planing on adding a turbo in the near future, and would like to know
what the 3 most important gauges are 4 keeping tabs on the engine. I am
building the car to be a sleeper, and need to conserve space. Also I dont want
them too cause any attention.
Old Sep 30, 2003 | 12:52 AM
NuclearB18B's Avatar
Default Re: What guages are most important 4 a 94 LS when adding a turbo (crosswrench)
i'm only using 2. boost and egt. those are the two really important ones anyway.
Old Sep 30, 2003 | 03:14 AM
Chris1091's Avatar
Default Re: What guages are most important 4 a 94 LS when adding a turbo (ha illuminato un)
boost, egt, and oil pressure.
Old Sep 30, 2003 | 03:31 AM
Scary1109's Avatar
Default Re: What guages are most important 4 a 94 LS when adding a turbo (Chris1091)
yes, you need the oil pressure too, the three mentioned are the ones i would consider "must haves"
Old Sep 30, 2003 | 04:38 AM
IMPATIENT's Avatar
Default Re: What guages are most important 4 a 94 LS when adding a turbo (Scary1109)
im using all the above(boost, oil pres, egt), but i also have air/ fuel ratio which to me is one of the most important along with the others, cause if your running lean, then thats why your egt's are a little warmer and thats why you should let off the gas and see whats going wrong, haha, i also have water temp for the simple fact that, having a turbo on the car is gonna heat it up, i like to monitor all the vitals of my car..........
Old Sep 30, 2003 | 04:49 AM
Ri5e's Avatar
Default Re: What guages are most important 4 a 94 LS when adding a turbo (IMPATIENT)
How did you get those two gauges to fit in the vent?
Old Sep 30, 2003 | 04:50 AM
IMPATIENT's Avatar
http://www.imagestation.com/pi...9.jpg
Old Sep 30, 2003 | 04:52 AM
IMPATIENT's Avatar
Default Re: What guages are most important 4 a 94 LS when adding a turbo (Tein Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tein Man &raquo;</TD></TR><TR><TD CLASS="quote">How did you get those two gauges to fit in the vent?</TD></TR></TABLE>
yea thats pretty damn tite........
lilshady6796
Nov 12, 2008 10:55 AM
pjr710
Jun 9, 2008 04:46 PM
Jay2005
Honda Civic (2006 - 2015)
14
Dec 17, 2007 02:41 PM
whole9
21
Jun 21, 2007 02:06 AM
G-Phi
Mar 18, 2004 01:55 PM
