How do you remove side moldings?
Old Aug 26, 2001 | 03:48 PM
Red2001GSR's Avatar
New User
Default How do you remove side moldings?
How do you remove the side moldings on 2001 Integra GS-R?
I would think they could just be pulled off... but then I could be wrong.
Is there a specific process to doing it?
Old Aug 26, 2001 | 05:08 PM
crookedletterd's Avatar
New User
Default Re: How do you remove side moldings? (Red2001GSR)
open your door, then you will see a litte bolt on the inside of the door. unscrew that and then pull them off carefully. dont break the clips because they fall in the door.
Old Aug 26, 2001 | 05:50 PM
98 Ek LsVtec's Avatar
Banned
Default Re: How do you remove side moldings? (integls98)
the right way to do it is unscrew that nut thats on the inside of the door then take off the door panel and use some pliers to take off the clips its easy just time consuming
alex1321
12
Jan 25, 2013 08:59 PM
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
truckhigh
10
Jun 7, 2005 06:09 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
