JDM Cluster in 89 Htb Help
Old Sep 29, 2003 | 04:39 PM
Garage_Biitz's Avatar
Default JDM Cluster in 89 Htb Help
I installed the cluster in to my 89 htb Si, now the problem is... I don't have dash lights and my dimmer is plugged in to and I've checked all the blubs too. And the second problem is, as soon as I turn the key on, the speedo goes to 60K and stays there. Ive check my wiring over and over again, I can't find any problems???
Old Sep 29, 2003 | 10:00 PM
Eggman's Avatar
Default Re: JDM Cluster in 89 Htb Help (Garage_Biitz)
i did a SiR cluster in my 89 too. same problem. the 90-91 dimmer switch is not plug and play for a 88-89. first check the fuse. i bet its broken. here's the post i made about it, awhile back... https://honda-tech.com/zerothread?id=318615. the solution is at the buttom of that post.
as for the speedo thing, check your wiring again. mine did that too, when i had the wiring off. does the speedo think its the tach?
Modified by Eggman at 10:01 PM 9/30/2003
Old Sep 30, 2003 | 07:09 PM
Default Re: JDM Cluster in 89 Htb Help (Eggman)
yea, even with the vss unplugged, it still goes to 60K. All the fuses look fine too, thats the wierd part. And that link doesn't work either.
Old Sep 30, 2003 | 09:04 PM
Eggman's Avatar
aww, sorry, try the link now. i just fixed it. make sure all your connections are on good. loose wires can cause crappy signals.
Old Oct 1, 2003 | 01:01 PM
thanks man for all your help, im going to try all that.
Old Oct 1, 2003 | 03:36 PM
I got the dash lights to work, thanks for your help. Im still having problems with the speedo, As soon as I turn the key on, it goes to 60k, but my tach works fine. I have the VSS wired to the ECU, B16 plug.
Old Oct 1, 2003 | 05:54 PM
Eggman's Avatar
alright time to recheck every wire. what diagram did you use to figure it out?
KevinEF7
13
Jul 26, 2013 10:35 PM
BIGef
Mar 23, 2012 06:20 PM
Joemaster
Jul 27, 2010 06:30 PM
confusion
May 13, 2007 02:22 AM
EG6. Civic
Dec 31, 2006 10:51 AM
