Is this 85 CRX worth $1,000
Old Sep 29, 2003 | 02:29 PM
blahbloop's Avatar
Default Is this 85 CRX worth $1,000
Ok, I really want this car, but the millege is a real killer, it has 180,000+ miles. Now I dont know if thats low or high for a 85 Honda. Also the guy that is selling it says its in pretty good shape, it starts up every morning. It needs some work which I am planning on doing if I get it. So is it worth $1,000? I test drove it and it runs fine, but the millege is what im worried about. It probably is worth it, but Im just making sure. Thanks!
PS: Also how is the body kit availibilty on a 85 CRX?
Old Sep 29, 2003 | 02:35 PM
Malgerus's Avatar
Default Re: Is this 85 CRX worth $1,000 (blahbloop)
Is it an Si? If it is, DEFINATELY get it... and yes the mileage is kinda high, but if it's clean and runs well... why not? It'd make a good beater at the very least. If you're gonna keep the stock engine, check stuff like the condition of the oil, coolant, see if it smokes, etc... also push the car up and down to see how good the shocks are, and wiggle the front tires to see if any suspension components are worn... just inspect it inside out, find stuff wrong with it, and see what kind money you can save by offering him less. Definately see what kind of shape the car is in before you buy it. If you don't know how, get a qualified mechanic to check it out. Most do it for relatively cheap.
Old Sep 29, 2003 | 02:38 PM
blahbloop's Avatar
Default Re: Is this 85 CRX worth $1,000 (Mr. S)
Yes it is a SI. Actually the guy that is selling it works at a place called Speed Tech. They supe up cars and all that stuff. Im planning on doing a engine swap when I get the money. Its somewhat clean, the dude is a smoker but I didnt smell any when I test drove it, the engine itself isnt that clean but im sure i can clean that. So is it still worth it?
Old Sep 29, 2003 | 02:40 PM
blahbloop's Avatar
Also he said 5th gear is out, but he said you dont really need it unless your going on a long trip.
Old Sep 29, 2003 | 02:57 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blahbloop &raquo;</TD></TR><TR><TD CLASS="quote">Yes it is a SI. Actually the guy that is selling it works at a place called Speed Tech. They supe up cars and all that stuff. Im planning on doing a engine swap when I get the money. Its somewhat clean, the dude is a smoker but I didnt smell any when I test drove it, the engine itself isnt that clean but im sure i can clean that. So is it still worth it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blahbloop &raquo;</TD></TR><TR><TD CLASS="quote">Also he said 5th gear is out, but he said you dont really need it unless your going on a long trip.</TD></TR></TABLE>
Well, as long as you're happy with the body and you don't care about the stock engine/transmission go for it. You'll likely swap out that tranny anyways. I believe the 85 Si is the absolute lightest USDM Si ever made, so it's a great choice for an engine swap... it's just more difficult to do one (the Si is fuel injected... right???).
Old Sep 29, 2003 | 02:59 PM
willybilson's Avatar
No way dude. I bought my 91 hf with 130k miles for 300 bucks. It runs and everything. Also i just bought an 88 Si for 250 but it had a blown head gasket. You're getting ripped man.
Old Sep 29, 2003 | 03:09 PM
blahbloop's Avatar
Default Re: Is this 85 CRX worth $1,000 (willybilson)
But i want this car dude and I cant find another CRX for sale. There is also a nice exhaust on it. It runs perfectly and is in good shape.
Old Sep 29, 2003 | 03:20 PM
MustangPunk302's Avatar
get it
Old Sep 29, 2003 | 03:35 PM
BAZ's Avatar
BAZ
1st gens rawk!
I had an '85 DX I got for $700 when I was 16.
That car was so much fun!
Make sure the body's in decent shape, especially the fenders. They are plastic and tend to crack, replacements are a bitch to find.
Old Sep 29, 2003 | 03:54 PM
xci_ed6's Avatar
Default Re: Is this 85 CRX worth $1,000 (BAZ)
I happen to have an engine, trans, sunroof, wiring harness, ecu, guage cluster and a **** ton of other parts out of an 85 Si (w/ 12?K), im or email me (krustindumm@yahoo.com).
Check the rear suspensoin out. Especially the panhard rod mounts. The reason I have so many parts is a rusted out panhard rod mount.
Also check:
all jack points
front floorpan corners
rear floor pan corners (behind seats)
spare tire well
If that stuff checks out, jump on it! 1Gs are sweet (my old S/N here was "Autocratic_1st_Gen").
-Dustin
Old Sep 29, 2003 | 04:18 PM
boosted_zc's Avatar
Default Re: Is this 85 CRX worth $1,000 (krustindumm)
Well if it needs a liitle work like you said and 5th gear is out on the tranny , there's a little negotiating room there. I'd offer 600-700. 1000 is a little high, even for an Si.
Old Sep 29, 2003 | 05:05 PM
DubbleD's Avatar
Default Re: Is this 85 CRX worth $1,000 (boosted_zc)
start by offering 600. then go from there
Old Sep 29, 2003 | 05:14 PM
u0f's Avatar
u0f
The car is not worth 1000$. I got my 86 si for half that. If it really is an 85 it is lighter than the 86-87's. If its not an si don't bother. Cant do much with the carb'd ones. If you want a body kit any 1st gen crx is a poor choice. There might be 1 or 2 ugly ones out there, and the mugen kit which is extremely rare. Take a look under the car. I used to have another 86 crx i used for parts and it was drivable but the car was so rusted the jack points were gone. There was no where to jack up the car because it was so rusted, wherever I placed the jack would crumble. These cars do run forever but you will want more power, and its not worth swapping a motor into a rotting car. Plus to do a b-series swap you will need 600$ mounts just to get in engine in the car.
Here is something to think about:
The parts car i bought costed 100$. It started up every time but it needed a headgasket, and it had the horrible rust. I swapped a few fenders, the seat, and the center console with my car, and then i sold it for 50$. It had 150k and still ran when i sold it. Do you think its worth it to spend 20 times that on a older crx with more miles?
Old Sep 29, 2003 | 05:32 PM
MarquesTGB's Avatar
Default Re: Is this 85 CRX worth $1,000 (u0f)
Consumer Rated Condition: Fair
"Fair" condition means that the vehicle probably has some mechanical or cosmetic defects, but is still in safe running condition. The paint, body and/or interior need work to be performed by a professional in order to be sold. The tires need to be replaced. There may be some repairable rust damage. The value of cars in this category may vary widely. A clean title history. Even after significant reconditioning this vehicle may not qualify for the Blue Book Suggested Retail value.
Private Party Value $675
Private Party value represents what you might expect to pay for a used car when purchasing from a private party. It may also represent the value you might expect to receive when selling your own used car to another private party.
from http://www.kbb.com
as far as the other stuff goes
http://www.andysautosport.com/honda/84_87CRX.html
Old Sep 29, 2003 | 06:25 PM
I8ayellowcrayon's Avatar
Hey WillyBilson, what part of MO are you from and how are you getting an 88 Si for $250 (even with blown HG)??? Maybe I need to pay you a visit.... Deals like that are hard to come by in NW Arkansas....
Old Sep 29, 2003 | 06:34 PM
b20_ed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blahbloop &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I really want this car, but the millege is a real killer, it has 180,000+ miles. Now I dont know if thats low or high for a 85 Honda. Also the guy that is selling it says its in pretty good shape, it starts up every morning. It needs some work which I am planning on doing if I get it. So is it worth $1,000? I test drove it and it runs fine, but the millege is what im worried about. It probably is worth it, but Im just making sure. Thanks!
PS: Also how is the body kit availibilty on a 85 CRX?</TD></TR></TABLE>
Ive seen 88-91 crxs go for that. With a lil over that mileage. Im not a fan of the 84-87 body style. But if the price is right.............
Old Sep 29, 2003 | 06:43 PM
xci_ed6's Avatar
Default Re: Is this 85 CRX worth $1,000 (b20_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If you want a body kit any 1st gen crx is a poor choice. </TD></TR></TABLE>
Houseman (i think-i don't believe it was andy's) picked up a NEVER BEFORE INSTALLED Mugen body kit, replicas will be here soon!
-Dustin
Old Sep 29, 2003 | 09:02 PM
b16_madman's Avatar
http://geocities.com/krustindumm/cars/JDMcrx.jpg
Old Sep 29, 2003 | 09:35 PM
Boosted-Ek's Avatar
Default Re: (I8ayellowcrayon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote">Hey WillyBilson, what part of MO are you from and how are you getting an 88 Si for $250 (even with blown HG)??? Maybe I need to pay you a visit.... Deals like that are hard to come by in NW Arkansas....</TD></TR></TABLE>
No kidding, I will come up there and buy a few. Bring them back here, and make some money.
Old Sep 30, 2003 | 08:54 AM
whizzlefist's Avatar
HEYHEYHEYHEY if you are intrested in a 1G go to http://www.redpepperracing.com it the king of 1g/3g
that is where the mugen replica Group buy is being held plus we can answer all your questions...
Check for rust always in the floor pan and the pan hard bar mounts... an 85 is rare and many people want them as the lightest FI car honda ever made...
Old Sep 30, 2003 | 09:06 AM
brent_G's Avatar
Default Re: Is this 85 CRX worth $1,000 (Ghost1)
i had an 86 si as my first car...paid 400 with a blown head gasket...had to change the spark plugs one a month on average, and put about as much oil in as gas. NOw it need a new everything as far as drive train is concerned...if anyone wants it...its free its white with green sap from the trees, musty interior, rear axle is still good has some slight damage in the front. no biggy tho
Old Sep 30, 2003 | 09:56 AM
8Grand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghost1 &raquo;</TD></TR><TR><TD CLASS="quote">HEYHEYHEYHEY if you are intrested in a 1G go to http://www.redpepperracing.com it the king of 1g/3g
Check for rust always in the floor pan and the pan hard bar mounts... an 85 is rare and many people want them as the lightest FI car honda ever made...</TD></TR></TABLE>
I think me and Ghose make it a point to send ppl to Redpepper when questions like this arise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Check for rust always in the floor pan and the pan hard bar mounts... </TD></TR></TABLE>
ALWASY check for rust... Mine rotted to **** and Im so pissed... there was probably little I could do, but the jack stops rotted to **** then the floors then the rockers and panhard was on its way too...
If the car is rusty on the under side then stay FAR away. If its clean then pick it up and keep it outa the salt int he winter if it snows where you are.
Old Sep 30, 2003 | 11:49 AM
Default Re: Is this 85 CRX worth $1,000 (screamincivik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamincivik &raquo;</TD></TR><TR><TD CLASS="quote">i had an 86 si as my first car...paid 400 with a blown head gasket...had to change the spark plugs one a month on average, and put about as much oil in as gas. NOw it need a new everything as far as drive train is concerned...if anyone wants it...its free its white with green sap from the trees, musty interior, rear axle is still good has some slight damage in the front. no biggy tho
dood 8 grand here is you shell you need
nihad
Nov 11, 2009 02:16 PM
nat_86CRXsi
Dec 21, 2005 10:41 AM
CRX_RACER2000
Jul 10, 2004 08:08 AM
crxforum
Dec 24, 2001 11:01 AM
Chaze*R
Nov 25, 2001 03:57 AM
