Quick ? from Opie...
Old Sep 29, 2003 | 12:22 PM
Opie's Avatar
Default Quick ? from Opie... It's about my nuts and bolt...
Was checking my recently installed spark plugs yesterday, and while putting my spark plug wire cover back on i accidently snapped one of the 4 bolts that secure the cover. Now I know that it won't hurt, because it didn't snap that low, but it just irks me. I find myself starring @ that baron hole with hatred.
Can I fix?
Is there a replacement that doesn't require me taking my valve cover off?
Thanks, just pissed off.....
Old Sep 29, 2003 | 12:29 PM
RTW DC2R's Avatar
Default Re: Quick ? from Opie... It's about my nuts and bolt... (opie112)
If you are talking about the bolts/studs I think you are, then its a common thing with B series(all Honda?) motors. I broke 2 of mine in one damn day. That was a day of hell. Fortunately I had enough thread left where I could smash the rubber washer/bushing, turn the nut upside down, and tighten it enough to keep oil from spilling all over the place.
anyway only way to fix it is get new studs. They arent hard to replace and just requires taking off the valve cover. Call up Len and have him send you a few so you have some extras lying around. I seemed to tend to break mine when the motor was HOT. So now I dont touch those bolts unless the motor is ice cold.
EDIT: get my nuts and bolts confused
Modified by RTW DC2 at 4:42 PM 9/29/2003
Old Sep 29, 2003 | 12:30 PM
Opie's Avatar
Default Re: Quick ? from Opie... It's about my nuts and bolt... (RTW DC2)
Thanks guy Dont wanna take my cover off never been off still has virginal tightness.... i will if i got to..
Old Sep 29, 2003 | 12:41 PM
bus stop's Avatar
if you decide to take off the valve cover.....you may need to replace the valve cover gasket (and some Hondabond)
Sic_DA_Nine
Feb 1, 2008 09:30 AM
stuie08
Aug 14, 2007 12:01 AM
DarkDragon
May 25, 2005 07:34 PM
propulsion1
Oct 31, 2004 03:47 PM
bluesicruzzin
May 1, 2004 09:03 PM
