integra jdm conversion important questions!!!!!!!!
Old Aug 26, 2001 | 01:55 PM
makattack's Avatar
New User
Default integra jdm conversion important questions!!!!!!!!
hi wondering if the fiber glass is better than sheetmetal? plus can i put it together my self? and will the kit fit perfectly????
Old Aug 26, 2001 | 03:42 PM
bb6h22a's Avatar
Default Ok....
..the sheetmetal or oem front end is the best fitting and looking front end available, and will fit ALL 94+ integras. Also, you can in fact assemble and install the front end yourself, and if you do get the oem front end [i.e. from Honda of Japan] it will fit perfectly! Also, depending on if you get the HID lights or the halogens you will have to do some wiring to get the HID's to work, don't worry its all there!
Here are some links for you to check out:
www.c-speedracing.com
Look under front end conversion
http://patriot.net/~merritt/tech.html
Look under JDM ITR Front End
Good luck..
Old Aug 26, 2001 | 04:07 PM
GZR4DR's Avatar
Default Re: Ok.... (bb6h22a)
Sure if you know how to weld, you can put the front end by yourself. But for the rest of us without an arc welder and the skills required to use it, you have to take it to an autobody place to weld in the radiator support.
BTW the fiberglass kit doesnt fit right. The OEM kit looks much better.
d_mina
Aug 29, 2006 02:44 PM
BARTEG
Jan 31, 2006 08:04 AM
princemictmonilbj40
Apr 30, 2005 06:53 PM
vaajboy
Aug 29, 2004 09:45 AM
pg_thao
Jun 3, 2003 02:25 PM
