whats the best compression?
Old Sep 29, 2003 | 11:30 AM
kboy01gsr's Avatar
Default whats the best compression?
what would be the best compression for a daily driven GSR?
Old Sep 29, 2003 | 11:56 AM
JCushing's Avatar
Default Re: whats the best compression? (kboy01gsr)
what octane?
Old Sep 29, 2003 | 02:46 PM
TwoRedEGgs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kboy01gsr &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best compression for a daily driven GSR?</TD></TR></TABLE>
that depends on your mods, if its stock then u can get away with running 89 but you will loose some power, 91 is prolly the best to use, and safe for about 11.5-1 compression after that you may want a little higher !
Old Sep 29, 2003 | 02:59 PM
justBLZE's Avatar
Chopper 2 Hopper
12.3 on 93.
Old Sep 29, 2003 | 04:50 PM
JD Milan's Avatar
Default Re: whats the best compression? (tommySI)
it depends on application, for street driven NA i say 12:1 but that all depends on tuning, you can go higher but it must be tuned for that.
Old Sep 30, 2003 | 04:45 AM
00 FBP ItR's Avatar
Default Re: whats the best compression? (JD Milan)
11.5-11.7 on 91.
Old Sep 30, 2003 | 04:56 AM
advanracing62's Avatar
Default Re: whats the best compression? (00 FBP ItR)
17:1 depending on available fuel and tuining....
Old Sep 30, 2003 | 07:55 AM
TwoRedEGgs's Avatar
Default Re: whats the best compression? (advanracing62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">17:1 depending on available fuel and tuining....</TD></TR></TABLE>
rrrrrrrright, hope your kidding.......17.1-1 on a daily driven car, u might wanna be a milionare to run that high, cause that compression ain't cheap, and i don't know to many gas stations that pump over 100 on a regular basis !
Old Sep 30, 2003 | 09:35 AM
Team 4's Avatar
Default Re: whats the best compression? (TwoRedEGgs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoRedEGgs &raquo;</TD></TR><TR><TD CLASS="quote">
rrrrrrrright, hope your kidding.......17.1-1 on a daily driven car, u might wanna be a milionare to run that high, cause that compression ain't cheap, and i don't know to many gas stations that pump over 100 on a regular basis !</TD></TR></TABLE>
Or you own a Diesel.
Old Sep 30, 2003 | 09:42 AM
91TegLS's Avatar
what do you guys think the highest you can safely run with 94 octane is? because that's all I run
Old Sep 30, 2003 | 09:58 AM
99-DC2's Avatar
with proper tuning no higher than 12.8
Old Oct 1, 2003 | 10:28 AM
HmgLauj69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">11.5-11.7 on 91.</TD></TR></TABLE>
how's it runing? any problems? how safe can you go with 91 anyways, damn cali
ndlyng
Jul 24, 2006 07:27 AM
Rhymenoceros
15
Apr 15, 2006 03:59 PM
RenzoDaPlayboi
Nov 13, 2005 03:31 PM
24K SI
Sep 3, 2004 07:40 AM
booscivic
Aug 12, 2003 05:46 PM
