extra cable on head unit, 94 prelude Si
Old Sep 29, 2003 | 07:18 AM
humtake's Avatar
Default extra cable on head unit, 94 prelude Si
im changing out my head units. i unmounted hte stock head unit and found all the wires i need for the harness to attach...however there is a thicker black cable that is hooked to it! the cable goes towards the shifter, not the front of the car so i assume its not a hot wire. i know the head unit has a code anti-theft system, is that what this is for? i need tyo know if i can just cut it off so i can install my new head unit.
Old Sep 29, 2003 | 10:23 AM
PhazedSI's Avatar
Default Re: extra cable on head unit, 94 prelude Si (humtake)
Sounds like the antenna cable to me. Is it hooked into the back of the head unit on the right side looking above the deck w/ the faceplace pointing towards you?
Old Sep 29, 2003 | 12:19 PM
special_edition's Avatar
Default Re: extra cable on head unit, 94 prelude Si (PhazedSI)
For a second there, I thought you were referring to the cylinder head. Yeah thats your antenna cable...plug it in, plug it in.
Old Sep 29, 2003 | 12:20 PM
humtake's Avatar
yep, its the antennae cable. as i went out there to work on it while waiting for an answer, i saw a wire that said power antannae and thought that was the wire, but it turns out it was exactly as you said...i guess everyone comes up with a moronic situation every now and then!
johanG
Audio / Security / Video
Jan 1, 2009 09:48 AM
oddmut
23
Jan 25, 2008 08:21 PM
teggsr925
Dec 30, 2006 03:12 PM
SkRiBLaH
Oct 11, 2005 09:35 AM
Mase
Mar 27, 2002 01:09 PM
