Can you blow your head with now Downpipe? Also, what about Mccord PP?
Old Sep 28, 2003 | 10:32 PM
racinskittle's Avatar
Default Can you blow your head with now Downpipe? Also, what about Mccord PP?
I've heard you can blow your head or burn out your exhaust valves with no downpipe. Is this true?
Cuz im a little worried about the Mccord power plate now. Ill have a 2.5inch downpipe to the 3 inch mccord power plate.
Will this cause head damage?
Old Sep 29, 2003 | 01:32 AM
intekragsr's Avatar
Default Re: Can you blow your head with now Downpipe? Also, what about Mccord PP? (racinskittle)
Logically, I do not see how and open downpipe has ANYTHING to do with the valves. Maybe you will blow it from making too much power ?
Old Sep 29, 2003 | 01:34 AM
project dc2's Avatar
Default Re: Can you blow your head with now Downpipe? Also, what about Mccord PP? (intekragsr)
well .. its kinda like .. turning your car on with no header on. the major temperature differences when the cars on. is the motor slightly sucks IN air and the heat difference will cause the valves to bend. hence by running no downpipe the possibility of the valves bending. the answer is. with at least a small downpipe it should be perfectly fine. just as long as your not running straight off the head.
Old Sep 29, 2003 | 05:04 AM
Default Re: Can you blow your head with now Downpipe? Also, what about Mccord PP? (project dc2)
Alright, I wont worry about it then.
Thanks for the reply.
H-allmotorda9
17
Feb 6, 2010 07:40 PM
AntMan401
Mar 17, 2008 02:13 PM
Jeter2NYC
Jun 15, 2006 06:44 PM
satan_srv
May 4, 2003 10:08 AM
satan_srv
May 2, 2003 05:51 PM
