Suggestions on Aftermarket Headlight Bulbs
Old Sep 28, 2003 | 08:47 PM
N1NjA TuRtLE's Avatar
Default Suggestions on Aftermarket Headlight Bulbs
My integra's headlight bulbs are very dim and i can barely see **** at night.
I want some brighter bulbs. Anyone kno which ones are good and last a long time.
I have heard PIAAs tend to burn out after a year or 2. But i'm lookin into PIAAs because they seem to look bright and nice. But what do you guys suggest? And feel free to post pics. And no i already made my mind i do not want a HID system. Thanx
Old Sep 28, 2003 | 08:59 PM
Default Re: Suggestions on Aftermarket Headlight Bulbs (YellowSpoonEG6)
Also if anyone knows any websites that sells bulbs that'd be great.
Old Sep 28, 2003 | 09:13 PM
no one has aftermarket bulbs?
Old Sep 28, 2003 | 09:33 PM
Old Sep 28, 2003 | 09:40 PM
Bill Hook's Avatar
autolamps-online.com
Go to Roadfly.com, then the BMW message boards, then the lighting forum.
A guy named Daniel Stern, pretty much THE auto lighting guru, despite the occasions when he's wrong and/or full of himself, can answer your questions.
He also posted the latest comparison of euro-spec halogen bulbs. I posted a thread recapitulating his links to that test in this forum. Euro-spec are usually quite a bit better than US spec bulbs. We, here in the US, are enamored of HID look bulbs, rather than bulbs that make much difference in output.
Also, look for the automotive lighting forum.
http://bimmer.roadfly.org/bmw/forums/lighting/
Specifically:
http://bimmer.roadfly.org/bmw/...age=1
Here's the auto lighting forum:
http://www.network54.com/Hide/Forum/216460?it=0
Modified by Bill Hook at 7:13 AM 9/29/2003
Old Sep 28, 2003 | 09:59 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
hands down the best way to get more light for the least money is a 9005 conversion w/ Sylvania Cool Blue headlights. I used to have that and they lasted 1.5 years before one burned out. At only $15-$20/pair, that's not bad for 1.5 years of life and 70% increased light output.
click the link in my sig for a how-to
Old Sep 28, 2003 | 10:01 PM
NuclearB18B's Avatar
Default Re: Suggestions on Aftermarket Headlight Bulbs (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">hands down the best way to get more light for the least money is a 9005 conversion w/ Sylvania Cool Blue headlights.</TD></TR></TABLE>
i don't know about them being that much brighter, but definitely brighter.
Old Sep 28, 2003 | 10:05 PM
xkhalil333x's Avatar
i have piaa superwhites. i used them on my car in 99 then put them in storage till i bought my new tegra which they still work
Old Sep 28, 2003 | 10:07 PM
Bill Hook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">hands down the best way to get more light for the least money is a 9005 conversion w/ Sylvania Cool Blue headlights. I used to have that and they lasted 1.5 years before one burned out. At only $15-$20/pair, that's not bad for 1.5 years of life and 70% increased light output.
click the link in my sig for a how-to</TD></TR></TABLE>
You sure that cool blues are really best? Consensus would be that coated bulbs mean reduced light.
I'd say that I would go with any UNCOATED 9005 bulb that is rated at the maximum legal wattage of 65 watts, from a name brand maker, for the conversion.
I've used other Sylvanias that meet this criteria and have had them last only around 6-8 months. Rated life is 300 hours for 9005, vs. 1000 for 9006. I DO drive w/ lights on most of the time, as the South isn't known for conscientious drivers.
He did ask for the best bulbs, so buying euro spec would qualify. The output of a 50%+ bulb would be close to the 9005 conversion and the life would be 3X greater.
Modified by Bill Hook at 7:25 AM 9/29/2003
Old Sep 28, 2003 | 10:08 PM
Bill Hook's Avatar
Default Re: Suggestions on Aftermarket Headlight Bulbs (ha illuminato un)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un &raquo;</TD></TR><TR><TD CLASS="quote">
i don't know about them being that much brighter, but definitely brighter. </TD></TR></TABLE>
1700-1900 lumens (9005), vs. 1000 lumens for 9006.
Personally, I'm trying to get HIR2s, which are the equal of the 9005 in output, but last almost as long as 9006.
For the highs, I'm also getting HIR1s, which are almost as bright as HID bulbs.
Problem is, they have to be shipped from Germany, then to Canada, then to me.
Old Sep 28, 2003 | 10:20 PM
Default Re: Suggestions on Aftermarket Headlight Bulbs (Bill Hook)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bill Hook &raquo;</TD></TR><TR><TD CLASS="quote">autolamps-online.com
Specifically:
Modified by Bill Hook at 7:13 AM 9/29/2003</TD></TR></TABLE>
thanx a lot bro
Old Sep 28, 2003 | 10:22 PM
Bill Hook's Avatar
Oh, I should note that I believe that light out put of halogens is measured at 13.2 volts, which an older car, thorough increased resistance, via corrosion, would be lucky to achieve via 18ga. OEM wires.
Putting in a heavy duty wiring harness (SUVlights.com, Daniel Stern Lighting [preferred], etc.) can keep the voltage at optimum, which can buy you, perhaps 30% more output, depending on voltage drop.
One more proviso - stay the F--- away from 80W or 100W high output bulbs. I bought some Hellas from a nissan motorsport supplier, but decided melting my headlight housings wasn't worth it, after further investigation. Many HO bulbs aren't Hellas (= QUALITY), rather quite the opposite (= CRAP).
Modified by Bill Hook at 7:40 AM 9/29/2003
Old Sep 28, 2003 | 10:42 PM
Slain's Avatar
i've learned from my friends mistake either stay with oem bulbs or go hid's. seen so many people that burnout the blue bulbs in a matter of weeks.
Old Sep 28, 2003 | 10:46 PM
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">i've learned from my friends mistake either stay with oem bulbs or go hid's. seen so many people that burnout the blue bulbs in a matter of weeks.</TD></TR></TABLE>
yea i hear ya, many have told me piaas burn out a lot and other types of aftermaket bulbs
RedGSR's Avatar
Default Re: (Slain)
most of the time, it is because those kids don't know how to install them. Either way... nothing is wrong with regular bulbs. It is not worth spending $50 just to be different.
Old Sep 28, 2003 | 10:52 PM
Slain's Avatar
none of the instances i saw were of them being touched. everytime before putting a bulb in they would clean it off with a cloth and rubbing alcohol. i'm sick of seeing blue tinted bulbs on every car. its a shame that most of them are driving around thinking i'm the ****
Old Sep 28, 2003 | 10:55 PM
Default Re: (RedGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedGSR &raquo;</TD></TR><TR><TD CLASS="quote">
most of the time, it is because those kids don't know how to install them. Either way... nothing is wrong with regular bulbs. It is not worth spending $50 just to be different.</TD></TR></TABLE>
Well, something is wrong with my regular OEM bulbs, and that is that they're dim as **** and can't lit the road for jack ****. I'm in the market for some new bulbs and would like brighter bulbs whether they be aftermarket or OEM ones i just want something brighter and not at all trying to be Different.
Old Sep 28, 2003 | 10:58 PM
Slain's Avatar
it maybe your harness. bulbs either stay on or they go. unless you try a friends loaner bulb maybe. if it is indeed the bulb. just go to your local parts store and pick up said bulb. 9006 for dc ,9004 for da, h4h for one peice da applications hope that helps
Old Sep 28, 2003 | 11:01 PM
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">it maybe your harness. bulbs either stay on or they go. unless you try a friends loaner bulb maybe. if it is indeed the bulb. just go to your local parts store and pick up said bulb. 9006 for dc ,9004 for da, h4h for one peice da applications hope that helps </TD></TR></TABLE>
thanx, it's a 96 integra
Old Sep 28, 2003 | 11:02 PM
RedGSR's Avatar
Default Re: (YellowSpoonEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowSpoonEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
Well, something is wrong with my regular OEM bulbs, and that is that they're dim as **** and can't lit the road for jack ****. I'm in the market for some new bulbs and would like brighter bulbs whether they be aftermarket or OEM ones i just want something brighter and not at all trying to be Different. </TD></TR></TABLE>
All you need is just any new bulbs. More than likely, your current bulbs are just getting old. Nothing is really wrong with OEM bulbs. They are bright enough for daily driving. You don't need super bright headlights to blind other drivers. And I'm sure you don't need to be a riceboy bling bling with the blue headlights.
Old Sep 28, 2003 | 11:07 PM
Slain's Avatar
I'm sure you don't need to be a riceboy bling bling with the blue headlights.</TD></TR></TABLE>
now why dont we want to be blinging lol j/k if anything instead of banning the sale of HID's they should get rid of the FID's ( fid's=any blue bs bulb)
Old Sep 29, 2003 | 06:03 AM
Bill Hook's Avatar
Check out what i said about a heavy duty wiring harness. $50-$70. OEM wiring is the bare minimum acceptable to get power to the bulbs, over time these corrode and the resistance increases. With a wiring harness, all they need to do is provide switching inputs to a relay, which brings current direct from the battery.
Old Sep 29, 2003 | 06:07 AM
Bill Hook's Avatar
yea i hear ya, many have told me piaas burn out a lot and other types of aftermaket bulbs</TD></TR></TABLE>
Usually b/c they are overpriced crap. Buy something that is OEM for the Euro market and German made. There is no reason why they should burn out any sooner than the mediocre stuff that came with the car.
OR
Just find a good brand at AutoZone, etc. that is rated 65W and do the conversion PatrickGSR94 has linked and perhaps need to do it again in a year. Should be around $15-$20 each time.
NO BLUE COATED BULBS.
Old Sep 29, 2003 | 09:28 AM
Bill Hook's Avatar
Default Re: (Bill Hook)
http://candlepowerinc.com/
Seems to be perhaps the best website to find unique bulbs, but I'm unsure if they have a minimum order, something I'm trying to find out.
Old Sep 29, 2003 | 02:52 PM
All you need is just any new bulbs. More than likely, your current bulbs are just getting old. Nothing is really wrong with OEM bulbs. They are bright enough for daily driving. You don't need super bright headlights to blind other drivers. And I'm sure you don't need to be a riceboy bling bling with the blue headlights.</TD></TR></TABLE>
WTF? STFU gay ***. Did i ever even stated i wanted Riceboy Blue headlights bitch? why dont' you stfu ******** and fucken either contribute or stfu. Stop ******* bitching me about how oem bulbs are good or not good. If i am in the market of looking for aftermarket bulbs, then well the **** i will bitch and you ain't going to stop me so SHut YOUR ******* COMPUTEROFF and **** off this thread idiot. ******* either give out suggestions or don't fucken flame, stupid **** H-T members like you make me wanna go fucken rip your head off. What if i fucken have a sight problem bitch, what if OEMs aren't bright enough for me HUH? i want to get brighter ****, don't u fuken understand dickmunch? i like what i like bitch and i'll get wha i want. *** Off
