FS: Alpine MRV-T320 and Alpine MRD-M500
Old Sep 28, 2003 | 08:44 PM
TheBossman's Avatar
Default FS: Alpine MRV-T320 and Alpine MRD-M500
I have these two amp that are less than a month old and have less than 15 hours of use on them. Great amp, but due to new audio sponsorships I have to switch them out.
Alpine MRV-T320 - $175 Shipped obo
Product Specifications
The unstoppable power of the Alpine V12 Series MRV-T320 amplifier comes from the massive transformers and fast MOSFET power supplies. Extra-large capacitors deliver additional current when needed to fuel musical peaks. The amps are built using Alpine's STAR Topology design to greatly reduce internal noise, keeping the signal clean so that your speakers can perform better.
80 watts RMS x 2 at 4 ohms
110 watts RMS x 2 at 2 ohms
220 watts RMS x 1 in bridged mode
stereo or bridged mono output
Tri-Way capable
requires 10-gauge power and ground leads wiring and hardware not included with amplifier
variable 15-400 Hz high-pass/30-400 Hz low-pass crossover, 12 dB/octave
variable Bass EQ (0-12 dB of boost at 50 Hz)
MOSFET power supply
STAR Topology (minimizes internal noise and prevents ground interference)
speaker- and preamp-level inputs
oversized power and ground connections
gold-plated screw terminals
top-mounted controls with cover
detachable front cover
blue power LED
9-3/4"W x 2-1/2"H x 8-1/4"D
MRD-M500 Class D Mono Block - $250 Shipped obo
250 watts RMS x 1 at 4 ohms
500 watts RMS x 1 at 2 ohms
MOSFET power supply and output stage
STAR Topology for cleaner sound
Bass Engine® features:
Low-pass digital crossover
Variable subsonic filter
Parametric EQ
Bass Compensator enhances low-end definition
top-mounted digital control center with cover
time correction 0-10 milliseconds in 0.5ms steps
phase adjustment 0-180º
turn-on delay
digital readout
blue power LED
preamp outputs
extra-large gold-plated terminals
12-3/8"W x 2-11/16"H x 11-½"D
I have all the book and stuff that came with the amps, I just dont have the boxes since i cleaned up my garage :banghead:
Modified by TheBossman at 11:12 AM 10/8/2003
Old Sep 30, 2003 | 01:53 PM
TheBossman's Avatar
bump
Old Oct 8, 2003 | 10:12 AM
TheBossman's Avatar
Default Re: (TheBossman)
Old Oct 9, 2003 | 03:20 PM
TheBossman's Avatar
The 500 is SOLD
The 320 Amp I will let go for 150 shipped
Integra2316
Apr 7, 2007 05:34 PM
Aloha04MSM
Mar 22, 2006 07:46 PM
Aloha04MSM
CHONCH
Sep 10, 2003 09:43 PM
yoyoyo
Audio / Security / Video
Apr 15, 2003 06:54 PM
