FS: wow i got a lot of stuff!
FOR SALE:
- 98 gsr head from blown motor – damaged but repairable. Ported and valve job, completely bare head. $BO
- THREE US Type R pistons and rings. Blew motor, so 1 is gone. other 3 are in good condition. About 1000 miles on em: $100 OBO
- Set of p30 pistons, used for 600-800 miles, with rings. One rod failed, and rods are still on, but can be pressed out. All four are in great shape and very little carbon buildup. $200 with rings.
- Blue ion bulbs, for low beam g3 Integra: $20 OBO
- Stock LS shocks and springs, good condition, 50K miles – $BO
- Stock 95 LS turn signals - $40
- complete set of GSR valve springs: $BO
- 1998 GSR oil pan baffle - $20
- stock 1998 GSR valves: $BO SOLD
- 95 Integra cassette deck/radio: $BO
- 1998 GSR flywheel - $75
- 1998 Type R Trunk Brace - $75 SOLD
- 1998 GSR Alternator - $100
- 1998 GSR Thermostat - $40
- 1998 GSR pulley - $50
- 1998 GSR pcv (?) box - $20
- 1998 GSR distributor cap - $20
- 1998 GSR cam gears/sprokets - $10
- 1998 GSR intake manifold, complete with all sensors - $100
- 1998 GSR throttle body - $125
- Neuspeed front strut bar - $50 SOLD
- 1998 GSR head bolts - $25
- 1998 GSR oil cooler - $40 SOLD
- MSD 6AL and blaster 3 coil - $200
- 1998 GSR distributor, with MSD cap, wired for the 6AL - $100
- Iceman intake, for ITR/LS/GS/RS, with brand new filter. - $125
- Used K&N filter, approx 75k miles, # RU-3130 - $15 shipped
- 1998 GSR wiring harness - $200
- 1998 GSR power sterring pump - $50
- 1998 GSR AC compressor - $50 SOLD
- random tech cat - $50
- lower ball joint, brand new - $35
- 1998 GSR lower inside timing belt cover and upper inside timing belt cover - $25 for both
Also, misc audio stuff:
Baupunkt 4" coaxials (one has small hole on outside side that I covered with black tape-bass response is even better now!) used 2 months, been sitting at home 2 years - $40
Infinity Passive EQ, $40
Polk 5.25” speakers, model mm5520. Current equivalent model is the dx5. Sound excellent. - $90
Pics available for any of the above, email me for more info. –
magic1@pipeline.com
[Modified by Leo95SE, 9:16 AM 9/4/2001]
[Modified by Leo95SE, 8:57 AM 9/6/2001]
magic1@pipeline.com
if your that close over the bridge - ill meet you and give it to you for $60.
btw- this is the brace that goes on the rear wall, in between the lights, not the strut tower brace. thx.
JDMGuy, Riot:
whoever emails me will have first opportunity for it. JDMGuy first, since he asked first. I will send pics to show current condition.
Thanks
Thanks
hey man
got your voicemail.. i was tied up in the evening, thats why i tried getting a hold of you during the day.
I havent replied yet b/c im trying to see when ill be in NJ. im guessing maybe Friday. I will keep you posted. If im not, maybe early sat mornin (wanna avoid cross bronx traffic) or ill just mail it.
thx..
now.. where else do i have to reply?!?!
thx..
I want to buy the iceman filter......just the filter...i am making a custom intake...how much?
btw....can you tell me the size of the filter......Filter Length, Mounting Flange Inside Diameter, Filter Diameter......
thanks
thanks
I probably would provide more info off the bb, as my original post has my email address, but the used filter, which has about 75k miles on it, is a K&N RU-3130.
It needs to be cleaned, I just havent had the time to bother.
I will sell it for $15 shipped.
O, as a side note, the Iceman Filter is for LS/ITR. I'm assuming the intake was originally designed for an ITR, I believe the piping diameter is ~62mm, b/c it is the same size (AT the TB) as the TB. Intake diameter at the base, filter end, is approximately 3". (difference of ~0.5")
Thanks.
Thanks.
