what i need check list for b16a swap
ok i have a 91 crx that i just got and i have 6 grand to work with im planning on doin is a b16a swap i knwo i need axels, ecu, and tranny i was wondering if anyone else knew what else i need because i know theres more to it then that and also its a vtec so i need to wire the vetec up so if u have any tips on that , that would be a big help also if u think i should do a diffrent swap let me know im up for suggestions i already used the search button and i didnt find as much detail as i was lookign for
thank you
Alex
thank you
Alex
Alex,
Use the search function. There are tons of previous threads on this topic. You can also check out http://www.Hasport.com
The have some good info.
alex whats up, first off what model is your crx, if its a si or an hf your in good starting position, if not you need to go to hybridgarage.com look under archives, then tech library. your going to look for kenji's dx to zc wiring conversion, or get a wiring swap from hasport.com, second i recomend going to hmotorsonline.com pick out the motor you would like in your car not what everybody else is doing. i went with the b16. steve at hmotorsonline will hook you up great the swap i got looked brand new. he has everything you will need. good luck on your swap hope its everything you want.
madskilz98
Sep 25, 2008 09:17 PM
importgod21682
Dec 12, 2005 04:28 AM
