Help: Sway bar bolt fell off!?!?!
Old Sep 28, 2003 | 04:38 PM
BolivianDc2's Avatar
Default Help: Sway bar bolt fell off!?!?!
I was swapping out the axle portion of my exhaust when i noticed this:
i don't know when, or how it happend. What bolt do i need to get to fix this? And do i need some sort of bushing? About a year ago i got the bar installed by someone, i guess they must have done a shotty job.
Old Sep 28, 2003 | 05:00 PM
tilt's Avatar
Default Re: Help: Sway bar bolt fell off!?!?! (Bolivianstrtwpn)
http://www.acuraautomotiveparts.net/
or
you can pull the other bolt out and try to match it at your local hardware store like home depot.
The bushing appears to be intact on the endlink.
Old Sep 28, 2003 | 05:22 PM
six_speed's Avatar
Bolivianstrtwpn, you will need Metric 10X1.25..50mm? you should chance both bolts and get soem washers while ur added. Just incase the bolts are too long.
Or just buy the bolts, and go under ur car and guesstimate if you need washers or not.
Old Sep 28, 2003 | 06:47 PM
gsrclan's Avatar
Do you have itr bar or stock bar?
Old Sep 28, 2003 | 07:02 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Help: Sway bar bolt fell off!?!?! (gsrclan)
Once you get the new bolt, get some Loctite Red at your local auto store. It's an adhesive to keep the bolts from coming out. It's great stuff. I use it on my sway bar bolts. Mine used to back out too. Loctite fixed that.
Old Sep 28, 2003 | 07:03 PM
ITR if you couldnt tell from the picture
96Formula6spd
Jun 9, 2011 05:13 PM
effin
Apr 28, 2011 06:52 AM
lib
Mar 25, 2007 01:41 PM
JSJ EG6
Apr 1, 2003 07:14 PM
RevedOut
Feb 12, 2002 01:36 PM
