H22A SC
Checking to see if anyone has purchased different pullies from endyn for there JRSC. I am about to get mine installed but I don't know which belts I need. I got both pullies so I'm pretty sure both belts that I have won't work. Please help.
Depends what pullies your going to be using. If your using the 9lb jackshaft one you can use your same size belt and it's nice and tight, if your using the one on the blower im not sure but the same belt shouldn't fit because the pulley will be smaller then the original one.
