My first 1/8 run!
Old Sep 28, 2003 | 12:29 AM
Tru_Hybrid's Avatar
Default My first 1/8 run!
I don't know if this is bad or good, but this is my first time on 1/8 mile. Well..actually it was my first time drag racing ever. I took off at about 1100 rpm, so the R/T is really bad.
R/T 1.1
60' 2.9
330 don't remember
1/8 10.1
MPH 70.1
Old Sep 28, 2003 | 12:38 AM
Tru_Hybrid's Avatar
Default Re: My first 1/8 run! (TruHybrid_Honda_Integra)
Oh yea.. I almost forgot about my car and set-up.
Car: 1992 CX civic with 17" rims-Supra 712 tires
My engine is:
B18A LS Block-Stock
B16 Race Head-Port, Polish, and Milled
Civic Type R Cams
AEM Cam Gears
STR Fuel Rail
Custom Intake
97 Integra Type R Intake Manifold
MSD Inigtion
Type R trans. with LSD
ACT Street Clutch
Custom 2.5" Exhaust
JG Throttle Body
The car is untuned, and have a mess-up ECU due to a car flood.
Old Sep 28, 2003 | 12:54 AM
jarel's Avatar
not bad for your first time. Just work on your 60' and launching and you should be mid 9's or so.
Old Sep 28, 2003 | 05:16 AM
nsxmatt's Avatar
Your 60ft is awful, gotta work on that cause it kinda destroyed your run. The 70mph trap speed says high 9's though so that's not too great for your mods. I'd go to the track and try some more and see if you can improve.
Old Sep 28, 2003 | 07:01 AM
SlicksMH's Avatar
Hey for the first time, I give you a pat on the back John@M&H-Hashim's
Old Sep 28, 2003 | 09:05 AM
GSRGuy17's Avatar
Launching at 1100? Try holding your rpms at about 4000rpm, dropping your psi to about 22psi, and slip the clutch when you launch. 2.9 60' is just wrong... That should be somewhere in the 2.2-2.3s range at LEAST.
Old Sep 28, 2003 | 11:26 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: My first 1/8 run! (GSRGuy17)
launch at 5000 and feather the clutch, youll find that you might like slicks or radials better. Id get those. Im sure M&H would have somethin to suit you
Old Sep 28, 2003 | 01:06 PM
Archidictus's Avatar
Unceasing Measure
Default Re: My first 1/8 run! (OG Stunna)
Launching at 1100 has absolutely nothing to do with your reaction time. It does, however, have a lot to do with your 2.9 60'. That's just wrong. On the worst tires I've ever owned, my stock 93 Si hatch pulls 2.4's at a full 35psi.
Old Sep 28, 2003 | 02:02 PM
Stunna BEN's Avatar
Default Re: My first 1/8 run! (Archidictus)
yea, poor reaction is usually credited to sleeping on the light
Old Sep 28, 2003 | 02:06 PM
ITSTOCK's Avatar
Well, i ran a 9.7 in a civic hatch with d16z6, i/h/e, so just go back and get some practice, your car has alot more potential.
Old Sep 28, 2003 | 04:59 PM
Tru_Hybrid's Avatar
Thanks for the confidence...My R/T was so bad because I was really nervous. I will be practicing more on my launch. Hopefully I can get everything running right by next spring, maybe even a custom turbo by then as well. Thanks again eveyone!
Old Sep 29, 2003 | 02:50 AM
DA6GSR's Avatar
get the car tuned then go racing. You can be doing damage by racing it untuned.
Old Oct 12, 2003 | 08:45 PM
15_PSI_Civic's Avatar
Not bad for a first run. I noticed that you are from IA do you ever race down at MAM
Old Oct 12, 2003 | 08:51 PM
Accord_VTEC's Avatar
Default Re: My first 1/8 run! (15_PSI_Civic)
Thats really slow for an LS VTEC, me and J are working on custom turbos for LS Vtecs right now maybe we should meet up sometime. We could show you some of the work we have done.
Ding
Honda Civic (2006 - 2015)
Sep 9, 2006 06:31 PM
chadmasterc
May 16, 2006 01:59 AM
honda06si
Apr 10, 2005 02:19 PM
vtecmuscle
Aug 25, 2002 06:34 PM
pg_thao
May 14, 2002 11:27 AM
