will 92-95 civic susp. swap into a 94-96 integra?
Old Aug 25, 2001 | 09:37 PM
Thats-so-Ls's Avatar
New User
Default will 92-95 civic susp. swap into a 94-96 integra?
I need some suspension for my integra and i wanted to know if i can swap out the complete suspension from the civic into the integra? (i dont need ABS)
Old Aug 26, 2001 | 10:47 AM
jgale's Avatar
Default Re: will 92-95 civic susp. swap into a 94-96 integra? (Hatchypoo)
I don't know why you'd want to get the civic suspension, but, yes, it should work fine. IF you don't want the abs, I think you could remove all of the abs lines and module, and get a non-abs master cylinder and proportioning valve. Not sure though. Seems possible.
Old Aug 26, 2001 | 10:52 AM
SpiceyRice's Avatar
Default Re: will 92-95 civic susp. swap into a 94-96 integra? (jgale)
What's the difference between the ABS and non-ABS master cylinder..? I'm in the middle of putting all my R stuff in a 92CX hb and was planning on moving the brake system, minus abs... thanks
adrenalize
Honda Civic (2001 - 2005)
Jul 6, 2019 12:36 PM
tyb
Sep 3, 2013 02:05 AM
NeverOut215
May 4, 2013 04:24 PM
WhiteSlips
Oct 21, 2011 05:27 AM
