Sitting motor = loss of compression?
Old Sep 27, 2003 | 07:02 PM
blah13's Avatar
Default Sitting motor = loss of compression?
A friend of mine got a Si Hatch a while back which ran but not too great. He let it set for about 2-3 months while waiting for $ to do something with it and now it wont start. It turns but wont start. Replaced the battery and plugs, has fuel, has spark, timing is fine. The only thing he hasnt checked is compression but even when he added some oil to each cylinder it wouldnt start. Smoke came out of the exhaust while cranking. So can the piston rings go bad while just sitting? Maybe the cyl walls had fuel on them etc? I've had my old a6 on an engine stand for about 6 months and am just curious if that might affect that motor too.
Old Sep 27, 2003 | 07:21 PM
EG8R's Avatar
Default Re: Sitting motor = loss of compression? (blah13)
I see no reason why it wouldn't start.... Hmmz. Unless something electrical went wrong....
Old Sep 27, 2003 | 10:13 PM
JonGP4's Avatar
Default Re: Sitting motor = loss of compression? (skelly ed6)
yup those rings need to lube yup again, try spraying some starter fuild down the tb, while cranking sometimes when cars have been sitting they need some help to make fuel pressure
JDMkidGSR
Nov 29, 2012 06:57 AM
misha
41
Jul 15, 2009 06:24 AM
95gsrturbo
Sep 19, 2006 06:00 AM
