Powdercoating wheels
Are you looking for tips on actually doing the powder coating? Or tips on where/how to get it done?
Scott
http://www.SMPolishing.com
Scott
I guess the biggest tips are... prep, prep, prep. Prep work is the most time consuming and important part. Second, make sure everything is insanely clean, the smallest bit of dust or dirt can mess up the whole finish. Last, make sure your curing the powder coat at the correct temperature... 5 degrees can make a difference in the result.
Hope that helps...
Scott
Hope that helps...
Scott
