Info post about throttle body sizes...
Old Sep 27, 2003 | 05:26 PM
ScubaStevo80's Avatar
Default Info post about throttle body sizes...
I was planning on running a GSR motor with a skunk2 IM which if I'm not mistaken has a 64mm opening. Now my question is this... I've seen people say to match that 64mm size and some port match and others use different throttle bodies... so far I've heard that the b16 and b18's TB's are 58mm and 60mm, the itr's is 60 and 62mm, the jdm itr's is 64mm, the s2000's is 62 and 64mm and the h22's is 62mm. If anyone knows the correct numbers for certain, can they list them.... thanks.
B16
B18c
B18c5
H22a
F20c
Old Sep 27, 2003 | 05:48 PM
b19coupe's Avatar
Default Re: Info post about throttle body sizes... (VolpeOwnsU)
GSR is 60mm.
ITR is 62mm.
Old Sep 28, 2003 | 06:23 AM
Fred n J_v2.0's Avatar
Default Re: Info post about throttle body sizes... (b19coupe)
B16 a1:58 a2:60
B18c 60
B18c5 62
H22a 60
F20c 62
Old Sep 28, 2003 | 07:34 AM
Default Re: Info post about throttle body sizes... (95VXFRANK)
Thanks... Since they're all 60 or 62mm, it doesn't really matter which you buy then if you're going with an aftermarket manifold like the skunk2, right?
Also, are the JDM tb's the same size as the USDM ones?
lil_blue_si
Oct 26, 2007 03:26 PM
jdm_loser
Jul 19, 2004 01:24 PM
shotty527
Nov 7, 2003 12:18 PM
