Video of my car and dyno 596whp***
Guest
Posts: n/a
Ok I wenyt dyno today and video everything. I originally went to tune cams but ended up raising the boost
. Did 596whp 391 torque.
I have another video but its big ...and forgive me for the poor website etc but im still learning this video and website thing and its a lot.
2000 honda civic coupe
Full race prepared head
B18c5 motor
9-1 cr JE pistons
Crower Rods
GE sleeves
Ferrera Valves
Tilton Carbon/carbon clutch
Str intake manifold
Custom equal length stainless steel exhaust manifold
Weldon fuel pump
4x 1000cc injectors
Haltech e6k
msd dis2
Turbonetics t-70 turbo
Turbonetics Race Gate
Spearco Water to Air intercooler
Greddy profec A boost controller
Hks racing blow-off valve
Full chromoly chassis w/partial fiberglass body panels
uses VP c-16 race fuel
DSS stage 5 axles
Custom Trick suspension
Skunk2 coilovers
The chassis was purchased from John Brown of JBR racing(previously Castrol Civic featured in SCC magazine)
Motor built byJohn Brown
Chassis builty by Rosado Racing
Tuned by Prentice Ali of Peak Performance (Trinidad)
Driver/Owner Gerald Aboud
Best time 10.59 (still tuning phase)
Modified by saso at 3:52 AM 9/28/2003
Modified by saso at 12:50 PM 10/2/2003
. Did 596whp 391 torque. I have another video but its big ...and forgive me for the poor website etc but im still learning this video and website thing and its a lot.
B18c5 motor
9-1 cr JE pistons
Crower Rods
GE sleeves
Ferrera Valves
Str intake manifold
Weldon fuel pump
4x 1000cc injectors
Haltech e6k
msd dis2
DSS stage 5 axles
Skunk2 coilovers
Trinidad?
My girlfriend's from there. Her brothers go back every year for carnival. I didn't even know they had performance shops out there let alone a track, by the way it was described to me?
Great numbers though
Why not turn it up a tad bit more for the 600 club?
Real close to that 600whp and 400ft-lb torque mark. Congrats! Did you swing the gears at all? How much boost? edit:33psi? to 35psi, it seemed like it didn't hit peak until right at redline?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saso »</TD></TR><TR><TD CLASS="quote">4th gear pull, 33psi. T70 baby</TD></TR></TABLE>
Then did you cut the pulls short by 1000 rpm from your old dynos? It is way shorter than the last dyno you showed.
edit: I can see you were inthe same gear because it DOES overlay up close in lower gears but you can see your old runs you pulled about 1500rpm more almost. Good ish anyways!
If you pulled higher 600whp was there dude!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">
If you pulled higher 600whp was there dude!</TD></TR></TABLE>
Have you passed 600yet with that t67?
If you pulled higher 600whp was there dude!</TD></TR></TABLE>Have you passed 600yet with that t67?
Have you passed 600yet with that t67?</TD></TR></TABLE>
Not yet but I feel if the gasket did not blow at 8700 it would've hit 600whp. WE shall see soon, I have another head being put on now, stock and RLZ engineering is doing a ported head for me http://www.hondaraceengines.com I will go get a baseline run with this stock head though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votebam1090 »</TD></TR><TR><TD CLASS="quote">that is nuts. straight up nuts</TD></TR></TABLE>
exactly
exactly
