Need help ASAP - What clutch for YS1
Old Sep 27, 2003 | 04:36 PM
ericb16hf's Avatar
Default Need help ASAP - What clutch for YS1
I need to know what clutch to get for my 1st gen b16a w/ ys1 cable trans. I bought a hyperclutch kit for a 90-91 integra and it will not work. Thanks is advanced for any help.
ericzccrx
Old Sep 27, 2003 | 04:40 PM
1's Avatar
Default Re: Need help ASAP - What clutch for YS1 (ericzccrx)
Any 92 and up clutch for b-series will work.
Old Sep 27, 2003 | 04:47 PM
ericb16hf's Avatar
Default Re: Need help ASAP - What clutch for YS1 (1)
So when I order my clutch it should be for what ? 92 integra ?
Old Sep 27, 2003 | 04:54 PM
ericb16hf's Avatar
Does anyone know if the release bearings are the same ? I have a 90-91 release bearing on my trans now, will it work ?
Old Sep 27, 2003 | 05:30 PM
Hondasaurs's Avatar
The clucth has to be for a B16/17 or a GSR. The input shaft is smaller in the non-vtec B series trannys. This should also answer your question about the throwout bearing.
Old Sep 27, 2003 | 08:54 PM
Speed PHreak's Avatar
Default Re: Need help ASAP - What clutch for YS1 (Hondasaurs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondasaurs &raquo;</TD></TR><TR><TD CLASS="quote">The clucth has to be for a B16/17 or a GSR. The input shaft is smaller in the non-vtec B series trannys. </TD></TR></TABLE>
The input shaft is only smaller on the 90-91 trannies, not just non-VTEC trannies. The JDM S1/J1 use the same throw out bearing and clutch as a 90-91 'teg. However the 92-93 YS1's(yes there is more than one, an LS version and a GSR version) have the bigger sized b-series input shaft that they've been using since 92.
Old Sep 27, 2003 | 10:02 PM
cavakilla's Avatar
Default Re: Need help ASAP - What clutch for YS1 (Speed PHreak)
to be sure count the number of teeth on your trans input shaft. and let them know when you order any quality catalog has both options... good luck tom
Old Sep 27, 2003 | 11:12 PM
Nerologic's Avatar
wait i was just told that you could not run a 92+ b series cluth here:
https://honda-tech.com/zerothread?id=625310
Old Sep 28, 2003 | 08:37 AM
ericb16hf's Avatar
So.... I understand that I need a clutch disc for a 92+ Integra, now I need to know if the piolet and Release bearings are the same for all cable Trannys or if there is a difference beteen the 90-91, and 92-93. I'v already installed my release and piolet, and would like to leave them alone if possible. Let me know, this is the only thing holding up my swap at the momment. Thanks
Old Sep 28, 2003 | 11:37 AM
Nerologic's Avatar
if u read the link i posted it means u CANT use the 92+ with the cable ys1
Old Sep 29, 2003 | 01:41 PM
ericb16hf's Avatar
Then what do I use for a clutch then ?
Old Sep 29, 2003 | 06:50 PM
TheBestCRX's Avatar
Default Re: (ericzccrx)
get a 92-93 integra clutch and you will be ok.
csk239
Transmission & Drivetrain
Jan 4, 2009 10:49 AM
gtfour43
Jul 16, 2004 08:12 AM
R91Si
Mar 8, 2004 05:44 AM
7PSiEF9ZC
Aug 3, 2003 11:03 AM
7PSiEF9ZC
Jul 31, 2003 04:14 PM
