Fuel Trim??
Hey guys..got my codes checked agian today and found out 3 things...
1. Im running too rich
2.my 02 sensor circuit has a malfunciton with sensor 2
and 3. I have a fuel trim malfunction
Anybody have any imput?? I know that my 02 sensor is crapping out (causing me to run rich, but wouldnt the sensor 2 be referring to the secondary 02??) and I have no idea what a fuel trim malfunction is. Thanks a bunch!
Changing the O2 sensor may fix all your codes. Fuel trim is computer controlled and what it does is change your air fuel ratio so you can run stoichiometric or as close to it at all times. And it uses the signal from your O2 to do so. If your O2 isnt functioning properly it gives a bad signal. than the computer thinks fuel trim isnt functioning and sets a code.
Perfectionist
Oct 8, 2006 02:00 PM
the soL that could
Feb 17, 2006 09:27 AM
