master cylinder?
i have a 88 crx si and i am low on brake fluid, will that cause my peddle to go alll the way to the floor when i press it to stop? if i get a new master cylinder should i get a 90-93 teg one, a 90-91 crx si one or a stock one cuz i am doing rear disc swap this coming week? thanks
if you get the master cyllinder from the integra, you should get the booster too. the teg mc will not bolt to your stock booster. also make sure to get the mc and booster from a non abs integra. as on the abs mc, one of the fittings for hardlines is different and not easily replaced.
adrian1281
Aug 23, 2003 09:43 PM
