Clifford concept 400
Old Sep 27, 2003 | 04:00 PM
User 5426's Avatar
Default Clifford concept 400
I was tring to program a new code into my alarm but it seems to have programed the wrong code. Do you guys know if I need the original reciept to get the code reset to factory.
I don't have the reciept because I purchased the car with the alarm already installed.
Old Sep 27, 2003 | 06:21 PM
User 5426's Avatar
Default Re: Clifford concept 400 (SeaQuake)
any installation guide? any help?
Old Dec 28, 2003 | 07:02 PM
romJones's Avatar
did u check clifford.com?
they got the manual online on how to reset ur program using the user-input code key
good to see someone wit the same alarm sys
Old Dec 28, 2003 | 10:11 PM
Quad-Damag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaQuake &raquo;</TD></TR><TR><TD CLASS="quote">I was tring to program a new code into my alarm but it seems to have programed the wrong code. Do you guys know if I need the original reciept to get the code reset to factory.
I don't have the reciept because I purchased the car with the alarm already installed.</TD></TR></TABLE>
you need to use the cliffort tool, it's the software that cliffort dealers have, they can reset ur code and take off the master code and set up ur tones and what nots, it has alot of extras, it's called the cliffort wizard, most dealers have em, go to http://www.clifford.com and check for local dealers in ur area, we do that at the shop i work at
Old Dec 29, 2003 | 08:20 PM
User 5426's Avatar
Default Re: Clifford concept 400 (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge &raquo;</TD></TR><TR><TD CLASS="quote">
you need to use the Clifford tool, it's the software that Clifford dealers have, they can reset ur code and take off the master code and set up ur tones and what nots, it has alot of extras, it's called the Clifford wizard, most dealers have em, go to http://www.clifford.com and check for local dealers in ur area, we do that at the shop i work at</TD></TR></TABLE>
Do you mean Cliffnet wizard sir? Hmmm, I may buy this.
Old Dec 30, 2003 | 11:38 AM
romJones's Avatar
does anyone else have problems with the sensitivity levels on this particular alarm?
Old Dec 30, 2003 | 02:57 PM
User 5426's Avatar
Default Re: Clifford concept 400 (romJones)
This is one of the first alarm in which I don't have problems with sensitivity. I love the fact that the sensitivity is remotely adjustable, which makes setting sensitivity a breeze.
Old Dec 30, 2003 | 06:07 PM
romJones's Avatar
even thou it is fully adjustable (which i love btw), i still have the problem of it goin off randomly. i kno that having metal objects around the proximity sensor can set it off. but even after i've cleared it all away, i still seem to have this problem. any suggestions?
Old Dec 31, 2003 | 09:22 AM
rody084's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaQuake &raquo;</TD></TR><TR><TD CLASS="quote">I love the fact that the sensitivity is remotely adjustable, which makes setting sensitivity a breeze.</TD></TR></TABLE>
how do you remote adjust it?
i have the concept 300 which i think is the same thing except less accessories... i am trying to bypass the shock sensor remotely...but i am not sure how to do it
Old Dec 31, 2003 | 02:09 PM
User 5426's Avatar
Default Re: Clifford concept 400 (rody084)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rody084 &raquo;</TD></TR><TR><TD CLASS="quote">
i have the concept 300 which i think is the same thing except less accessories... i am trying to bypass the shock sensor remotely...but i am not sure how to do it</TD></TR></TABLE>
I don't know off the top of my head but here is the user manual for your alarm system.
Old Jan 8, 2004 | 05:52 PM
romJones's Avatar
does anyone know if u can upgrade this particular model so u can have the pager?
Old Jan 8, 2004 | 05:58 PM
Quad-Damag's Avatar
just install a 2ed alarm and have the cliffort control the locks, add on a Viper 791 VX those are the cheapest of the DEI Pager Alarms with the 1/4 Mile range they are not 1/2 bad, the new CF Look is mad tight YO!
buy em on ebay they are mad cheap.
J K R
Audio / Security / Video
Jul 3, 2009 10:59 AM
redludevtec
Sep 28, 2004 06:16 PM
EricUSC
Jan 13, 2004 06:15 PM
georgeda
Mar 12, 2003 09:57 AM
