Parking Lights wire??? HELP
i dont know which wire is the parking lights wire..this is for EG ex cluster..there are 3 plugs back there..of the three plugs, i need to tap in the parking lights wire..thanks (which color wire??)
On your stereo plugs there is a wire for the dimm feature when you turn your lights on.
I dont know what color it is but if you have an aftermarket stereo with a plug it will be labeled
Or if you have a Volt meter go behind the dimmer switch ( the adjustable one that controlls the inside dash lights brightness) and find out which one have voltage when you turn it on
on the fuse box there are 4 or 5 male spade terminals..you need to test them but i'm pretty sure the 3rd on is parking lights....its a negative trigger....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">On your stereo plugs there is a wire for the dimm feature when you turn your lights on.
Or if you have a Volt meter go behind the dimmer switch ( the adjustable one that controlls the inside dash lights brightness) and find out which one have voltage when you turn it on</TD></TR></TABLE>
why would you want to dim your parking lights..
plus it wont work unless you got a higher fuse rate instead of the stock 10amp version.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG »</TD></TR><TR><TD CLASS="quote">
plus it wont work unless you got a higher fuse rate instead of the stock 10amp version.</TD></TR></TABLE>
It doesnt dimm your parking lights.. the dash dimmer has an input when you turn on the parking lights you tap into that wire, and the stereo dimmer light changes the brightness on your stereo and is activated by your parking lights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG »</TD></TR><TR><TD CLASS="quote">on the fuse box there are 4 or 5 male spade terminals..you need to test them but i'm pretty sure the 3rd on is parking lights....its a negative trigger....</TD></TR></TABLE>
3rd is (+) hot when parking lights are on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
3rd is (+) hot when parking lights are on</TD></TR></TABLE>
then use a relay and switch the trigger...my bad..if you get a relay i can tell you how to wire it....they are usually $5..and get it from a local car audio shop...
cameron
Modified by TurboB16aEG at 4:47 PM 10/11/2003
cameron
mitchh29
31
Mar 30, 2013 12:13 PM
jdmej814
Lighting
Jan 30, 2008 02:07 PM
