b18 swap no spark!
Checked the timing it was WAY off I set it tdc on the cams and crank only, both cams arrows point stright up right?
then replaced teh coil and ingnitor and cap with my known to work Si distributor...and still no sparky
It should fire even with some unattached vacuum hoses right?
and what if timings off by a tooth I should still be getting spark no?
Oh and Im not seeing the rpms fluctuate when cranking.
im stuck help thankx
aflyingpanda
12
Jul 26, 2012 05:19 AM
purplexs650d
Oct 17, 2006 12:31 PM
XJamesX
13
May 29, 2006 10:10 PM
