retarding ignition
Old Sep 27, 2003 | 01:01 PM
GimpyDowns's Avatar
Default retarding ignition
need advice. whats the best way to go without spending alot of money for an ignition system that will automatically retard my ignition when i spray n20?
or is there a way i can do it without buying anything? how would having my ignition retarded like 2 degees all the time affect daily driving?
zex wet kit 55 shot - want to do 65 maybe 75
cant post more than 5 a day as trial user so i just edit stuff in
Modified by crapfase at 12:57 AM 9/28/2003
Old Sep 27, 2003 | 01:50 PM
Shakes's Avatar
space cadet
Default Re: retarding ignition (crapfase)
what in the hell is no2??
N2O on the other had is what you are talking about. i too need to know what people are using to get retarted.
Old Sep 27, 2003 | 02:32 PM
NirVTEC's Avatar
Default Re: retarding ignition (shakes)
I don't know that its answering your question but I took the easy route with an MSD dig6. It retards timing, and has a 2 stage feather touch rev-limiter.
I want to say cost was around $325
Old Sep 27, 2003 | 02:57 PM
md23vtec's Avatar
what shot r u gonna use? What kinda kit aslo?
Old Sep 27, 2003 | 03:26 PM
NirVTEC's Avatar
Default Re: retarding ignition (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">what shot r u gonna use? What kinda kit aslo?</TD></TR></TABLE>
I should have asked as well. If you're planning on a 50 shot, no worries about timing. Anything more and you will need to.
60 shot ~-1*
70 shot ~-2*
Old Sep 27, 2003 | 03:43 PM
Shakes's Avatar
space cadet
Default Re: retarding ignition (NirVTECn2o)
75 and 100 shot here. direct port NX
also please tell me more about the digi 6. is it constantly retarded or does it only retard when you spray?
also does anyone know much about the JNMM??
Old Sep 27, 2003 | 04:02 PM
ChargedLude97's Avatar
Digital 6 is a constant retard once you set it.
Old Sep 27, 2003 | 05:19 PM
Shakes's Avatar
space cadet
Default Re: (ChargedLude97)
ouch... talk about slow around town... know of any that arent??
nobody seems to know anything about the JNMM.....
Old Sep 28, 2003 | 03:43 AM
GimpyDowns's Avatar
Default Re: (shakes)
couldnt you just hook your msd digital 6 up to a switch? so its retarded when you want? just flip it on when your gona shoot? or to a tps switch maybe? zex forsure and nx might sells a tps switch thing ment to activate your nitrous, would activating a msd while driving and on top of that spraying mess **** up?
i have no experience with msd ignition systems....
Old Sep 28, 2003 | 11:07 AM
NX and Zex both use full throttle switchs, not sure how'd you wire a msd box in to that and even if you did if for some reason it didn't come on you might get a boom
Old Sep 28, 2003 | 01:00 PM
GimpyDowns's Avatar
well they both sell the tps voltage sensing unit, just get your msd its own and when your progming it push the pedal down almost all the way.. then it should come on right before you shot always... could work? if it did how safe would this be?
Old Sep 28, 2003 | 08:31 PM
solowerks's Avatar
Some how you would need to train the ignition system to know when you hit Wide open throttle like the zex dry kit
Old Sep 28, 2003 | 11:59 PM
GimpyDowns's Avatar
Default Re: (solowerks)
i was talkin about, make a tps switch turn the msd on.. what would happen if you had your msd turn on while running?
man... theres gota be a easier way to do this ... how does having your ignition retarded say 2- 4 degrees affect normal performance anyways?
Old Oct 11, 2003 | 07:09 PM
7808's Avatar
Default Re: (GimpyDowns)
msd sci+ retards when you spray i think
MARVNVRAM
Oct 2, 2007 03:53 AM
shhh151
May 26, 2006 08:20 PM
boosted k20
Apr 5, 2005 07:04 AM
Shakes
Sep 28, 2003 11:05 AM
p1ccoloz
Mar 9, 2003 04:18 PM
