Anyone with a 88-91 civic w/ b16a and a drag tubo kit
Old Sep 27, 2003 | 12:22 PM
civicjdmb16a's Avatar
Default Anyone with a 88-91 civic w/ b16a and a drag tubo kit
what radiator can i use if stock one keeps overheating. theres only about 45mm to play with before it hit the turbo housing.
Old Sep 28, 2003 | 04:20 AM
Fobtions's Avatar
Default Re: Anyone with a 88-91 civic w/ b16a and a drag tubo kit (civicjdmb16a)
im thinking the overheating is not because of your radiator size.
Old Sep 28, 2003 | 11:16 AM
Default Re: Anyone with a 88-91 civic w/ b16a and a drag tubo kit (Fobtions)
have any suggestions on why im over heating. i have already changed my themostat, water pump, and the ect sensor. the car will over heat and then i kill the engine for about a minute and turn it back on and the temp. will jump up to about 3/4 of the way up and then instantly drop back down to normal operating temp.
Old Sep 28, 2003 | 11:35 AM
B20Monster's Avatar
are you checking to see if your fan is coming on?> that might be the cause of the overheating.
Old Sep 28, 2003 | 12:15 PM
r7's Avatar
r7
Default Re: Anyone with a 88-91 civic w/ b16a and a drag tubo kit (B20Monster)
overheats when? wot? curising? what kind of AFR's?
Old Sep 28, 2003 | 12:26 PM
brent_G's Avatar
Default Re: Anyone with a 88-91 civic w/ b16a and a drag tubo kit (r7)
is your radiator new? check the bottom part of the radiator where you cant see...it could be starting to corrode and rust there...most people cant see it...but when you take it ouit its in pretty rough shape and doesnt do its job anymore. Happened to me.
Old Sep 28, 2003 | 12:45 PM
rZiViC's Avatar
I know what your problem is. I'm sure your problem is your temp. sensor or some people call it temp. switch and if does'nt fix your problem. then it's your collant sensor If your collant sensor is not working that will make your car overheat. just check the stuff that i mentioned
swzen
Honda Civic (2006 - 2015)
May 12, 2014 04:54 PM
oneEg1Tc
Apr 20, 2009 06:55 AM
JDM_Silver
May 30, 2007 09:03 AM
Al-sonic
Jan 12, 2007 10:38 AM
95stangkillah
Aug 9, 2004 09:21 AM
