Home Depot tuning back at it again...
Old Sep 27, 2003 | 12:05 PM
B Speed's Avatar
Default Home Depot tuning back at it again...
Modified by B Speed at 9:31 AM 10/7/2004
Old Sep 27, 2003 | 12:07 PM
snapcase318's Avatar
Default Re: Home Depot tuning back at it again... (B Speed)
Awesome, I saw function over form any day. No about that winshield wiper fluid cover.....
Old Sep 27, 2003 | 12:11 PM
B Speed's Avatar
Default Re: Home Depot tuning back at it again... (snapcase318)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snapcase318 &raquo;</TD></TR><TR><TD CLASS="quote">Awesome, I saw function over form any day. No about that winshield wiper fluid cover.....</TD></TR></TABLE>
heh, clowns at Jiffy Lube lost mine, and the Suzuki dealership I bought my car at went under.
So for now it is aluminum duct tape with holes in it...
Once the new Suzuki dealership opens, I'll order an OEM one...
Old Sep 27, 2003 | 12:51 PM
Doctor CorteZ's Avatar
that wire has so much resistance I doubt you noticed anything at all other than the placebo effect.
Old Sep 27, 2003 | 02:47 PM
B Speed's Avatar
Default Re: Home Depot tuning back at it again... (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">that wire has so much resistance I doubt you noticed anything at all other than the placebo effect.</TD></TR></TABLE>
Well, I know what you're saying... However, I went out and did some more driving and there were noticeable improvements when accelerating and shifting, as well as the other improvements I mentioned.
Old Sep 27, 2003 | 02:53 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
thats weird your valve cover says suzuki
Old Sep 27, 2003 | 02:59 PM
B Speed's Avatar
Default Re: (1 point 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">thats weird your valve cover says suzuki </TD></TR></TABLE>
Actually, thats the valve cover cover...
Old Sep 27, 2003 | 03:05 PM
ki3t's Avatar
This user can set his title.
Dang, pretty good ojb y0!
Old Sep 27, 2003 | 03:31 PM
ITRbroham's Avatar
shit post warrior
Default Re: Home Depot tuning back at it again... (B18cR-Ej1)
Nice work!
Old Sep 28, 2003 | 12:56 PM
B Speed's Avatar
Default Re: Home Depot tuning back at it again... (ITRbroham)
Thanks for the compliments guys...
Old Sep 28, 2003 | 01:00 PM
JoshuaVTEC's Avatar
Function over form, yeah... but that looks like a rat's nest.
Old Sep 28, 2003 | 02:06 PM
B Speed's Avatar
Default Re: Home Depot tuning back at it again... (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Function over form, yeah... but that looks like a rat's nest. </TD></TR></TABLE>
Not really... it's only 4 wires...
Would definitely be better with black wires...
Old Sep 29, 2003 | 05:04 AM
Red CiViC Hatch's Avatar
what function does it serve.......never understood those things..........
Old Sep 29, 2003 | 05:50 AM
itsJDMyo's Avatar
Default Re: Home Depot tuning back at it again... (Red CiViC Hatch)
where exactly did you ground the wires?
Old Sep 29, 2003 | 05:52 AM
B Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red CiViC Hatch &raquo;</TD></TR><TR><TD CLASS="quote">what function does it serve.......never understood those things..........</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B Speed &raquo;</TD></TR><TR><TD CLASS="quote">
Seemed to make a difference when driving with AC on, as well as holding power better when letting off the gas in low gear at high RPM</TD></TR></TABLE>
Also, it has been holding power better during shifts.
Old Sep 29, 2003 | 07:22 AM
ill phil's Avatar
And you found the wires at HomeDepot? I never could find good copper wiring when I tried to make one from HomeDepot. Did you test the wires with an ohm meter to see if there was any improvement in quality and size?
Old Sep 29, 2003 | 06:15 PM
B Speed's Avatar
Default Re: Home Depot tuning back at it again... (ill phil)
yup. Home Depot is the place to be... Lowe's has it too. Same stuff, same prices basically.
I didn't test their resistance, but they are bigger than the stock grounds (which are 10 AWG)
Old Sep 29, 2003 | 07:21 PM
PatrickGSR94's Avatar
Community Builder
Active Streak: 60 Days
Default Re: (B Speed)
Actually, thats the valve cover cover... </TD></TR></TABLE>
No actually it's the camshaft cover cover
I still want to do this, 8 ga. wire will suffice. I have found that audio wiring is usually more flexible than the stuff you buy at the hardware store (made for home wiring). They usually also contain more copper in cross section due to having much smaller and many more strands than the hardware store stuff.
Old Sep 30, 2003 | 11:34 AM
B Speed's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I still want to do this, 8 ga. wire will suffice. I have found that audio wiring is usually more flexible than the stuff you buy at the hardware store (made for home wiring). They usually also contain more copper in cross section due to having much smaller and many more strands than the hardware store stuff.</TD></TR></TABLE>
True, but audio wire costs a lot more.
Old Sep 30, 2003 | 01:31 PM
Archidictus's Avatar
Unceasing Measure
I made mine with Home Depot stuff a long time ago. Smoothed out my idle and allowed my accessories to work better. Definately worth the $10 I spent.
Old Sep 30, 2003 | 03:22 PM
B Speed's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I made mine with Home Depot stuff a long time ago. Smoothed out my idle and allowed my accessories to work better. Definately worth the $10 I spent.</TD></TR></TABLE>
Glad someone here can corraborate my info...
Old Oct 2, 2003 | 05:39 PM
ill45's Avatar
lets see some pics of the car now
Old Oct 2, 2003 | 08:04 PM
ghettols's Avatar
Default Re: Home Depot tuning back at it again... (ill45)
very nice!let me know if you makin' one for an integra
Old Oct 2, 2003 | 09:43 PM
DarkProject's Avatar
Default Re: Home Depot tuning back at it again... (ghettols)
Cool. It's nice that you used red wire as ground wire.
Old Oct 2, 2003 | 09:45 PM
infinatenexus's Avatar
why didn't you go with crimp on connectors?
